Posts: 1253 Joined: Wed Feb 27, 2013 3:00 pm
Post
by Audilard » Fri Oct 07, 2016 9:31 pm
As you can see in this picture of my 2.5 euro block the bottom oil pressure switch threaded hole is much bigger than the 7a or 3b or aan blocks. Any ideas, leads or suggestions for a larger switch or one I can order?
Post
by Audilard » Fri Oct 07, 2016 9:32 pm
The check valve is as that is the same.
yodasfro
Posts: 156 Joined: Fri Aug 02, 2013 11:50 am
Post
by yodasfro » Sat Oct 08, 2016 10:22 am
You need the adapter 034103179 supersedes to 074103179 common on most I5 blocks.
yodasfro on Sat Oct 08, 2016 6:09 pm, edited 1 time in total.
A1QSHIP
Posts: 109 Joined: Thu Jul 04, 2013 6:16 pm
Post
by A1QSHIP » Sat Oct 08, 2016 10:33 am
http://audi.7zap.com/en/rdw/audi+a6+s6+ ... 103020/#26
#26 in the picture. The adapter is found on many I5 engines.
On a 7a Coupe the oil pressure switch is mounted there. IMG_1776.JPG (1.85 MiB) Viewed 15090 times
On my S6 I installed an oil line to a remote mounted oil pressure gauge sender. IMG_1775.JPG (1.74 MiB) Viewed 15090 times
Nulla tenaci invia est via
Post
by Audilard » Sat Oct 08, 2016 5:13 pm
yodasfro wrote: You need the adapter 034103179 common on most I5 blocks.
Besides a used block. Know where I can get one?
yodasfro
Post
by yodasfro » Sat Oct 08, 2016 6:07 pm
