Euro block oil pressure switch....help
As you can see in this picture of my 2.5 euro block the bottom oil pressure switch threaded hole is much bigger than the 7a or 3b or aan blocks. Any ideas, leads or suggestions for a larger switch or one I can order?
Re: Euro block oil pressure switch....help
The check valve is as that is the same.
yodasfro
Post by yodasfro »
You need the adapter 034103179 supersedes to 074103179 common on most I5 blocks.
A1QSHIP
Post by A1QSHIP »
http://audi.7zap.com/en/rdw/audi+a6+s6+ ... 103020/#26
#26 in the picture. The adapter is found on many I5 engines.
On a 7a Coupe the oil pressure switch is mounted there.
On my S6 I installed an oil line to a remote mounted oil pressure gauge sender.
Nulla tenaci invia est via
yodasfro wrote:You need the adapter 034103179 common on most I5 blocks.
Besides a used block. Know where I can get one?
yodasfro
Post by yodasfro »
