Josh's 2.5 200QT.
2.5TYPE44
Re: Josh's 2.5 200QT
Post by 2.5TYPE44 »
Actually, I need to back pedal on something I said. This build is supposed to be a high horsepower daily driver and I want to keep the usable power practical. I want to build boost at a decent rpm which is why I have chosen to use the stroker crank, quick spool valve, extensive head work, and the turbo with a gamma ti impeller. It is easy to get caught up chasing after higher horsepower numbers until you realize that the higher you go, the bigger the turbo needed, and smaller the power band is. We will just have to see how fast this spools up. No need to change it if it is fun and practical to drive just to earn some bragging rights on an extra 50hp or so.
That's a healthy attitude to have :-)
on my stinking phone!
2.5TYPE44 wrote: the higher you go, the bigger the turbo needed, and smaller the power band is.
Not so if you can rev high enough :thumbsup:
2.5TYPE44
Post by 2.5TYPE44 »
some cool 5cyl vids
2.5TYPE44
Post by 2.5TYPE44 »
I had to add these two. They were meant to be loaded the first time around
Love all of those :)
amd is the best
Post by amd is the best »
Win compilation. Missing that epic 200 launch though ;)
Nick
'00 A4 1.8t
'91 200 20v
'91 200 20v Avant
2.5TYPE44
Post by 2.5TYPE44 »
That's funny that you mention it. I had it as the third video bug I guess I loaded it the youtube brackets wrong and it didnt take it. The wife was yelling "come to bed". It will definitely go in that group.
Hank wrote:Holy smokes I can't believe that car is going to have 750whp
Ok, that car with that kind of power is just going to be flat out hilarious!
2.5TYPE44
Post by 2.5TYPE44 »
I hope that is a good hilarious :) ...
2.5TYPE44 wrote:I hope that is a good hilarious :) ...
Yes, VERY GOOD hilarious :)
2.5TYPE44
Post by 2.5TYPE44 »
I finally got around to putting in the passenger side Bose door card. While I was at it, I thought it would be pretty neat to try to make the rear doors to have Bose ported speaker boxes too. It would be easy to just cut in round speakers into the rear doors but what I have in mind is to try to glass in the rear panels and have them recovered to look factory. I wish Audi did this from the factory. Since I had an extra set of door cards left over from converting from the doo pocket style to the Bose, I had something to experiment and make mistakes with. Eventually, I want to get another set of front Bose grilles to blend into the rear door cards to make them look factory.
Bose rear clearance.jpg (719.71 KiB) Viewed 37493 times
rear Bose attempt.jpg (412.46 KiB) Viewed 37493 times
Front Bose conversion.jpg (384.67 KiB) Viewed 37493 times
2.5TYPE44
Post by 2.5TYPE44 »
The tinkering with my addiction has come to an end for a good while now. My car won't be in the garage to play with now. My face has broken out like a thirteen year old boy. My car was loaded up on a car hauler and left my house. I was stressed out seeing my car leave. It didn't make me comfortable that that driver didn't speak much English either. I am praying my car makes it alright. It has to make a stop in Phoenix, AZ. Then it is getting hauled to Los Angeles. After leaving California, it is on it way to Iroz Motorsport in Las Vegas where all of this hard work, money, and planning will take shape and the car will come alive. It is promised to be there by Friday at the latest. I haven't driven the car in five years and it has been in the garage for every bit of it. I am nervous but it is a good thing and it only means the project is moving closer to boosting down the road. I can't wait to drive it.
I'll be looking for it! We made a spot for it in the shop! It will be right in between 2 URQs an a 20vt 4kq for the time being! Good company!
2.5TYPE44
Post by 2.5TYPE44 »
Thanks, I can't wait until it gets there in one piece. I'll be able to sleep better at night.
Next thing you know, it'll leave that place with a 750whp 07k...
Hank wrote:I'll be looking for it! We made a spot for it in the shop! It will be right in between 2 URQs an a 20vt 4kq for the time being! Good company!
and they all are going to be ready for BBQ tuning, riiiiiiight?
FRCFD5
Post by FRCFD5 »
how'd i miss this... NICE!
Josh's head is one of the few AAN based heads that can give an 07k head a run for it's money... Stock that is :)
Marc, that is the plan :)
FRCFD5
Post by FRCFD5 »
What stage did you go with Josh?
Stage $$$$$. That is a stage right?
2.5TYPE44
Post by 2.5TYPE44 »
Oh we'll, you only live once and you can't take it with you when you leave. :D we can call it the "Done right with no short cuts" stage.
2.5TYPE44
Post by 2.5TYPE44 »
FRCFD5 wrote:What stage did you go with Josh?
Anyone unsuspecting and wants run will be told its a Stage ll. :lol:
lol
FRCFD5
Post by FRCFD5 »
2.5TYPE44 wrote:Oh we'll, you only live once and you can't take it with you when you leave. :D we can call it the "Done right with no short cuts" stage.
Same here... Jeff build my head.... I see you run the 92.8mm crank as well....Nice setup. What compression are you running and what cams did you go with?
