Josh's 2.5 200QT.
Re: Josh's 2.5 200QT
Actually, I need to back pedal on something I said. This build is supposed to be a high horsepower daily driver and I want to keep the usable power practical. I want to build boost at a decent rpm which is why I have chosen to use the stroker crank, quick spool valve, extensive head work, and the turbo with a gamma ti impeller. It is easy to get caught up chasing after higher horsepower numbers until you realize that the higher you go, the bigger the turbo needed, and smaller the power band is. We will just have to see how fast this spools up. No need to change it if it is fun and practical to drive just to earn some bragging rights on an extra 50hp or so.
That's a healthy attitude to have :-)
on my stinking phone!
Not so if you can rev high enough2.5TYPE44 wrote: the higher you go, the bigger the turbo needed, and smaller the power band is.
some cool 5cyl vids
I had to add these two. They were meant to be loaded the first time around
Love all of those
- amd is the best
Win compilation. Missing that epic 200 launch though
That's funny that you mention it. I had it as the third video bug I guess I loaded it the youtube brackets wrong and it didnt take it. The wife was yelling "come to bed". It will definitely go in that group.
Ok, that car with that kind of power is just going to be flat out hilarious!Hank wrote:Holy smokes I can't believe that car is going to have 750whp
I hope that is a good hilarious
Yes, VERY GOOD hilarious2.5TYPE44 wrote:I hope that is a good hilarious...
I finally got around to putting in the passenger side Bose door card. While I was at it, I thought it would be pretty neat to try to make the rear doors to have Bose ported speaker boxes too. It would be easy to just cut in round speakers into the rear doors but what I have in mind is to try to glass in the rear panels and have them recovered to look factory. I wish Audi did this from the factory. Since I had an extra set of door cards left over from converting from the doo pocket style to the Bose, I had something to experiment and make mistakes with. Eventually, I want to get another set of front Bose grilles to blend into the rear door cards to make them look factory.
- Bose rear clearance.jpg (719.71 KiB) Viewed 37497 times
- rear Bose attempt.jpg (412.46 KiB) Viewed 37497 times
- Front Bose conversion.jpg (384.67 KiB) Viewed 37497 times
The tinkering with my addiction has come to an end for a good while now. My car won't be in the garage to play with now. My face has broken out like a thirteen year old boy. My car was loaded up on a car hauler and left my house. I was stressed out seeing my car leave. It didn't make me comfortable that that driver didn't speak much English either. I am praying my car makes it alright. It has to make a stop in Phoenix, AZ. Then it is getting hauled to Los Angeles. After leaving California, it is on it way to Iroz Motorsport in Las Vegas where all of this hard work, money, and planning will take shape and the car will come alive. It is promised to be there by Friday at the latest. I haven't driven the car in five years and it has been in the garage for every bit of it. I am nervous but it is a good thing and it only means the project is moving closer to boosting down the road. I can't wait to drive it.
I'll be looking for it! We made a spot for it in the shop! It will be right in between 2 URQs an a 20vt 4kq for the time being! Good company!
Thanks, I can't wait until it gets there in one piece. I'll be able to sleep better at night.
Next thing you know, it'll leave that place with a 750whp 07k...
and they all are going to be ready for BBQ tuning, riiiiiiight?Hank wrote:I'll be looking for it! We made a spot for it in the shop! It will be right in between 2 URQs an a 20vt 4kq for the time being! Good company!
Josh's head is one of the few AAN based heads that can give an 07k head a run for it's money... Stock that is
Marc, that is the plan
FRCFD5
What stage did you go with Josh?
Stage $$$$$. That is a stage right?
Oh we'll, you only live once and you can't take it with you when you leave.
we can call it the "Done right with no short cuts" stage.
Anyone unsuspecting and wants run will be told its a Stage ll.FRCFD5 wrote:What stage did you go with Josh?
FRCFD5
Same here... Jeff build my head.... I see you run the 92.8mm crank as well....Nice setup. What compression are you running and what cams did you go with?2.5TYPE44 wrote:Oh we'll, you only live once and you can't take it with you when you leave.we can call it the "Done right with no short cuts" stage.
