'90 CQ - 4.0t Swap - WTB: Forged Control Arms
Haenszel
Re: '90 CQ - 4.0t Swap - Dash complete, Fans, quiet engine :
Post by Haenszel »
85oceanic wrote:Awesome progress! I can't wait to see videos of this thing on the road!
Me too! Right now I’m working on figuring out axles. I’ve fit b7 and b5 s4 front axles in the front spindles, and b5 s.4th rears bolt right up. I am working with DSS to utilize their b5 cv/hub upgrades, and the s8 inner cv’s. If they’ll work with me for custom bars that would be great. If they don’t, then I will move to another company.
B5 s4 big cv into CQ spindle.
How much bigger is the B5S4 CV than the Cq?
Haenszel
Post by Haenszel »
PRY4SNO wrote:How much bigger is the B5S4 CV than the Cq?
Beefy, and readily available. Nice.
Haenszel
Post by Haenszel »
PRY4SNO wrote:Beefy, and readily available. Nice.
Yeah I’ve never had a problem with them before, at 760+ ftlbs, so here’s to hoping!
the german
Post by the german »
I too can’t wait to see this thing driving. Everything about this project is winning.
If you need custom axles I used RCV Performance to make the ones for Quattromog. Top quality product and lifetime guarantee. Hard to beat that.
Kirk
1990 ABZ CQ
1990 lifted CQ
2005 S4 6MT
Haenszel
Post by Haenszel »
the german wrote:I too can’t wait to see this thing driving. Everything about this project is winning.
Excellent thanks. I’ll look into them! I’ll definitely be doing some calling around.
On another note, got the B7 S4 rear diff ready to drop into the car. Brackets done! This was actually a whole lot of fun!
Re: '90 CQ - 4.0t Swap - B7 Rear Diff Brackets
^^^^ more info on this would be great!!!
How do they compare on length at stock mounting position? Does it affect which axles and propshaft(s) you can use?
Haenszel
Post by Haenszel »
PRY4SNO wrote:^^^^ more info on this would be great!!!
Diff is the same length, same axle/driveshaft flanges, but the output flanges are slightly wider. Not much. Maybe 1/3” each. MIGHT be able to use stock axles. Havnt tried though.
Edit: Axle flanges are larger on B7, my mistake.
MikeB25
Post by MikeB25 »
Same final drive ratio?
'74 100LS (barn find)
'93 UrS4 (organ donor)
'08 Q7 (lemon)
'12 S4 (Stage 1...for now)
Haenszel
Post by Haenszel »
11” wide vs 11.75” wide at the flanges. Just measured.
And no, they’re not the same final drive, and I’m sure the b7 one is much stronger.
FFF
Post by FFF »
Great idea and the fabrication looks very good (I was tempted to say easy but stopped as it would take me quite a while!).
Haenszel
Post by Haenszel »
FFF wrote:Great idea and the fabrication looks very good (I was tempted to say easy but stopped as it would take me quite a while!).
Thanks, I got a few of the welds a little hot, but that’s fine with me. My first time fabricating anything with this new welder, and I love having the capability to do anything. My wife even said the welder has paid for itself already!
jretal
Post by jretal »
It might be different on the CQs, but the actual relay switch/button on my 4000, as well as my A4 were the things "responsible" for properly functioning signals and flashers. Might be something to look into/mess with if you're missing it.
Amazing work on the car!
rennenmsports
Post by rennenmsports »
This project is really looking good! I'm trying to put B5 S4 outer cv's in mine as well. Looking forward to reading more!
Haenszel
Post by Haenszel »
So this week I was really feeling like getting caught up on some things that I hadn’t gotten to but reallly were bothering me. Last Friday 2 friends came over, had some beers and removed the headliner and sunroof etc, broke a lot of old brittle interior trim while at it.
I replaced the metal sunroof with a glass panel, cuz I love real sunroofs. Then I got some rs2 grey oh shit handles and other little bits. Then I flocked the a,b and c pillars as well as the headliner in charcoal grey. It worked out really really well!! $60 and a couple hours to revamp the whole upper half of the interior and fix the VERY saggy headliner. While the headliner was out I also popped in a MK6 radio antennae shark fin. Classy.
I also had some time to rebuild/revamp the b6 rear calipers I had off of a part-out car in my driveway, so now we’re rockin b6 s4 300mm rear brakes! Excellent.
jbrentd
Re: '90 CQ - 4.0t Swap - Flock your life!
Post by jbrentd »
Looks really good, Brian
Haenszel
Post by Haenszel »
4.0t inner cv, to b5 outer cv custom length axles all the way around. Shipping out to have them copied in HyTuff alloy. Was quoted 1.5-2 week turnaround. It’s getting real.
FFF
Re: '90 CQ - 4.0t Swap - Custom axles
Post by FFF »
Haenszel wrote:
FFF wrote:Needs ground to initiate the turn signal lights in the display I should have said...
I can get the blinker/hazard light to light up in the dash no problem, but the actual blinkers don't work. I've tried both a 2 and 3-pin relay but can't seem to figure out where the blinker signal is sourced from. I figured the relay under the dash was the blinker relay but there was clearly something within the instrument cluster, not just a blinker light in there.
Did you ever get this sorted?
Haenszel
Post by Haenszel »
Havnt even tried yet. Haha. I will take a day sometime soon to get this, oil pressure and fuel level to read right. I just haven’t taken the time to get back into it.
FFF
Post by FFF »
Well it’s not like you haven’t been getting important stuff done!
pete82
Post by pete82 »
Look forward to seeing this driving around Buffalo.
If you need any help etc with info on removing trims and stuff i've had quite a few s2's/coupe's over the years.
What else you got planned once its running?
Haenszel
Post by Haenszel »
pete82 wrote:Look forward to seeing this driving around Buffalo.
Yo! Where are you from?
As far as plans, get it tuned and running great (will have to overcome some ECU issues I'm sure), and drive it a lot and not break it. Vroom.
Haenszel
Post by Haenszel »
Well over the recent weeks I've gotten the heat exchanger and welded up mounts to the radiator and packaged that up nicely, it just BARELY fits with the grille/bumper on, had to do a lot of trimming. I'm hoping an RS2 bumper will leave a bit more room for this.
New subframe came in to make more room for downpipes - There just wasn't enough room for 2 and to clear the axle before - now there is plenty of room for the axle so it won't melt every 8 seconds. I ended up redoing both downpipes a little bit, and I think this will work out a whole lot better. Downpipes are now finished, and exhaust is completely bolted up for final install all the way to the x-pipe, and braced to the transmission mount brackets
Axles also came in with an absolutely astounding turnaround time -- 10 days! all 4 are OEM '15 S8 inner CV's, and OEM B5 S4 outer CV's which should handle some power. I'm not sure the rear outer's will last forever, but they worked fine on my last car. I love these things, they're perfect.
Also finished up the rear part of the exhaust which came out amazing. Clearance is a little bit tight, so I had to go both over and under the axle, have approximately 1/4" clearance from the subframe/body in some parts so this is a bit tight, but I think it will work. Now I just need to mate the x-pipe/resonators to the rear portion, which should be pretty easy. The exhaust tips came out absolutely PERFECT. I spent a lot lot lot of time making them line up right, and i'm very happy. Nothing worse than having and exhaust look wonky.
Lastly, which front bumper do I get? regular RS2, or Widemouth RS2 to allow for much better cooling? I'm not totally sold on the widemouth, but it would be functional.
Other than that, suspension, brake adapters, driveshaft and S2 hubs are on the way and I will be out of town for 10 days so I'm hoping to get this thing bolted together when I get back and take it for its first real drive - with brakes this time! Hammer down.
rennenmsports
Re: '90 CQ - 4.0t Swap - Heat exchanger, exhaust, mufflers
beautiful work! That's awesome! I vote non-wide mouth. I always liked the sleeper and factory look
