Julian's '91 200 20vt
88a5tq
Post by 88a5tq »
Oh nice thanks. Lots a good prices. However, when I tell stories to people about how much money I saved by having a spare used sensor on hand, I prefer to use the DLR price for most impact :D Times 2 this go around.
88a5tq
Post by 88a5tq »
I was thinking today how cool this would look on the driver side across the doors real big
Do it
88a5tq
Post by 88a5tq »
loxxrider wrote:Do it
See, this is what makes our community so great here. Very supportive attitude. It's a tie between this and a big red FIRETRUCK! Jelly? I bet ;)
Except I just found the radiator leaking in one corner. Feck! I don't want to drop more than $150 on one tho. That rules out a correct Chinese ebay knockoff. Maybe a 5000 copper one? I put one in the 5k and it started looking "funny" on the one end tank crimp after 5 yrs. Only seen one ref to a brand and I think it was Nissin or similar (sp?) Yay, nay?
88a5tq
Post by 88a5tq »
yodasfro wrote:Try one of the ebay china aluminum units or just get a behr 20v rad. and call it good.
/\ this I think tho
Nissens rads have a spotty reputation, from my reading.
88a5tq
Post by 88a5tq »
Dam, alright new plan. Fcpeuro 5k behr rad with their automatic lifetime warranty. Yep can't lose.
88a5tq
Post by 88a5tq »
It's a shame my radiator is only an hour away lol. It's in transit so I won't see it until Monday.
With some available time I moved the catch can intake port from the k&n filter area to right in front of the turbo and tapped into the cobra head elbow. I think it turned out well.
There fixed
88a5tq
Post by 88a5tq »
Also in a strange stroke of luck concerning the fuel vapor line only under the car (which if you recall those shady mechanics refused to do...), I found that a 5/16" steel fuel line to 5/16" nylon fuel line adapter has a sort of pipe on the inside that 1/4" nylon line can be forced to sleeve over. I am pretty surprised it fits. The end by the fuel tank can be joined to the factory nylon line thats ~1/4" using a shark bite butt connector. Pretty cool. I may try doing the line today real quick after buying a HF pipe cutter for $6. I think the line will only see vacuum anyway. No risk of blowing apart. Its a damn tight fit though.
88a5tq
Post by 88a5tq »
Great success
Even cleaned everything up down there and got all the new lines, along with my w/m line, run in the OE keepers
88a5tq
Post by 88a5tq »
The freakin valve train sounds awful again. It's one valve only by the location of the sound. Before it went away but not this time. It persists even through an oil change.
I found the 034109309AD hyd. lifter (INA) from FCPEURO for $6.99 with free shipping and for only $4 from hansautoparts.com in the carolinas (unknown mfg. ) and $12 shipping. I'll call tomorrow about the manufacturer early in the morning. Maybe I better take an audio clip and post the youtube link after work to get other opinions. It kind of sounds like one lifter has completely bled down and isn't pumping up at all anymore. Idk tho
Aktapod
Post by Aktapod »
Julian's '91 200 19vt! ;) If you can, take a stethoscope to the valve cover (cheapo Harbor Freight one will do) to try and pinpoint which one is culprit. Hopefully it's just a lifter and not something more sinister.
88a5tq
Post by 88a5tq »
Lol its a very unique motor. One in the world! Ya I should probably find the problem valve first and then take a minute to focus on it and investigate while changing all of them.
The $4 lifter is made in China lol. No thanks.
Yeah, no.
88a5tq
Post by 88a5tq »
034 says I don't need any titanium items when changing to the supertech valve springs. No keepers or anything. I'm gonna order the springs (maybe factory direct :hide: ) as well as the INA lifters and borrow audi schwagen's valve compressor tool. Maybe I'll finish b4 the winter.
BTW anyone know the supertech 3b springs p/n :D
88a5tq
Post by 88a5tq »
Boy do I feel like a dick lol. Called supertech and they will only sell the springs, retainers and locators as a titanium kit for $550. They said if I only want the springs I need to buy from 034.
88a5tq
Post by 88a5tq »
Aktapod wrote:Hopefully it's just a lifter and not something more sinister.
Kevin, I'm gonna be REALLY mad at you if it turns out to be cylinder 1 rod knock! AAAHHHHhH! :bangshead: :wah: :wah:
I'm sweating bullets here.. it sounded like it was right next to the crank dampener pulley when I used a vacuum hose to listen. I have a garage to work in next door but it's gonna be f#cking cold this winter. Lol I'm sad. Not sure if I should tear into the engine or pinpoint the cause first. Not sure I want to know the cause! :boom:
The vac hose thing works OK, but try using a long screwdriver if you don't have a stethoscope. Works much better as you will actually feel it as well as new it.
88a5tq
Post by 88a5tq »
Thanks dave. I got set back a half hr tonight when the vac house I was using got tangled in the alternator belt and threw it off LOL. It was funny yes. I will likely invest in the HF one since it will probably be $4 hah. I may try that screwdriver but only if I manage to get it nowhere near the belts.
The noise doesn't sound as loud as the rod knock video I just watched. Can't barely hear it while driving even. I just threw up in my mouth alot.
PS my recent oil change didn't show anything weird or shiny in the oil but the ecs magnetic drain plug had a glob of fine shavings. Probably wasn't anything in the oil filter lol
Maybe post a video?
88a5tq
Post by 88a5tq »
Yep definitely will after work. I'd been listening to it all weekend and just didn't want to anymore yesterday so I took a break after putting the alternator belt back on.
More info: it quiets down intermittently during idle and while driving (IIRC), oil pressure is like it always has been and I've never seen it to be suspect. I thought the list would be longer 8-)
EDIT: I didn't notice any driveability issues at all. Car made full power and whatnot. The noise would increase at boost onset but quieted down after reaching full boost.
88a5tq
Post by 88a5tq »
I almost sort of suspect the water pump even.. video below.
https://youtu.be/SgpdkRvzOQ4
When I first started the car I thought the sound was gone! Nope it came back after a few seconds. Doesn't it sound too quick to be the rod knocking?
Oh that sounds yucky. Not like a lifter tick. But maybe a fubar lifter sounds different. And it sounds a lot louder down low... Maybe just because of the sound bouncing off the pavement, I'm not sure.
88a5tq
Post by 88a5tq »
I wasn't particularly psyched about the "down low" sound aspect.
Drive it? Lol
I did for 2 days with no increase in noticeability. Drives great hah
Also keep in mind that this happened, but louder, on my feckin birthday lol. Added 1/4 qt of oil over full and it stopped abruptly after driving a whole (short) block and not revving much higher than 3 to 4k rpm (25 mph zone). I just can't imagine at this point :shame:
88a5tq
Post by 88a5tq »
Piece of the old coolant heater core valve or thermostat caught in water pump?
I know it's forbidden but I think I'm gonna drain some oil and put a bottle of stp oil treatment in to see if it quiets down. At this point I don't have the resources or location to really dive into a full rebuild so I guess I'll drive it. I have another motor.
