bradyzq
Post by bradyzq »
a4kquattro wrote:
GTIVR62801 wrote:Are you bringing the CQ to Tremblant Marc?
yes :-D
Tremblant next week or end of September?
GTIVR62801
Post by GTIVR62801 »
End of September with ACNA/NEQ and BMW Club.
Toxcheap
Post by Toxcheap »
GTIVR62801 wrote:End of September with ACNA/NEQ and BMW Club.
Great let me guess the weekend of H20!!??
GTIVR62801
Yeah, unfortunately sacrifices will be made in the name of tracking. I haven't been to H2O in a few years now, kinda miss it. But given the choice between tracking and H2O, I choose tracking. Maybe next year if its not on the same weekend as Tremblant.
Toxcheap
Post by Toxcheap »
hmm I've never been to H20 and find myself really wanting to go this year :(
Audicted2quattro
Post by Audicted2quattro »
[/quote]
hmm I've never been to H20 and find myself really wanting to go this year :([/quote]
Haha you guys should def come thru, i went last year for the first time and i think its way better then waterfest, however its more laid back...no drag racing and stuff but its a fun weekend...
Marc:> When you going to EPL? Maybe ill take a trip out and visit...its about 2 hrs away
no firm plans yet, but Thursday was loosely discussed.
Update!
Didn't get a chance to go on the dyno yet. I let Brian Weldon drive the coupe down to //S fest because sadly I wasn't able to make it in person :-( (family event)
So this weeks project has been pulling the subframes and preparing for solid subframe bushings, delrin control arm bushings, and delrin rear diff mounts.
Rape, pillage, BURNINATE!
aftermath, after some cutting, swearing, and hammering
Subframes are now fully seamwelded and off at the sandblasting shop awaiting powdercoating (my oven isn't big enough to fit the subframes).
I'll be away in CT for the rest of the week so that will be all for now. I'm starting to sweat getting things done for Tremblant. Still need to install the S2 hubs, test fit wheels and tires, install new subframe bushings, and assemble everything.
Yikes.
a_CQ
Post by a_CQ »
LOL, when I saw that first pic the first thing that came to mind is you got pissed of and burned the whole damn thing....then I realized what's going on.
Why do you need S2 hubs, you already have brakes up front, no? So you can run wider wheels??
90_Koop
Post by 90_Koop »
a_CQ wrote:LOL, when I saw that first pic the first thing that came to mind is you got pissed of and burned the whole damn thing....then I realized what's going on.
I'm just guessing here but he's prolly wanting 5 lug and bigger brakes for the 3.6TT.
brakes are staying as is, reason for the 5 lugs is so I can share wheels with the wagon. I've already got two sets of track rubber in varying widths (255/40/17 for when the KW's arrive and 225/45/16 for the borrowed shine racing setup I've got on the car at the moment).
I already talked to Myke tonight about wheel bearings (oddly in my years of quattro ownership I've never once had to do wheel bearings!) but forgot to ask one question.. it looks like the wheel bearing has to be pressed back more than flush with the face of the knuckle, true? If so, what are you guys using as a press implement to touch only the outer race? Pressing up to the face was easy, just lay the bearing flat and press the kuckle onto it.. but cant go further than that without some kind of adapter.
Just my imagination, or are wheel bearing procedures NOT in the bentley?
gruppe5
Post by gruppe5 »
Race and bearing kit works wonders, your N75 valves are on the way, sorry for the wait.
a_CQ
Post by a_CQ »
I see. Yeah, being able to swap wheels between 2-3 cars is very nice.
As fo rthe bearings...use a race on the press...its simple.
Do you have top hats in 5x112 already? if so, who made them? I'm looking for somebody to make me some, but I have a 'custom' offset as I'm running machined UrS hubs up front.
gruppe5 wrote:Race and bearing kit works wonders
where is a good place to buy one?
ah, thanks!!!
a_CQ wrote:I see. Yeah, being able to swap wheels between 2-3 cars is very nice.
by that you mean another wheel bearing? That could work.
yes, I have one already. billzcat1 'old stock' from years ago :)
Derracuda
Post by Derracuda »
i usually use a socket as a spacer for the wheel bearings :)
derracuda wrote:i usually use a socket as a spacer for the wheel bearings :)
to press on the outer race, that would be a big damn socket... like 40+mm :-o
Derracuda
Post by Derracuda »
yup :D we got a drawer full of em'! we also have old wheel bearings laying around incase a socket doesn't fit good enough. it's always good to have a bunch of old crap like this laying around.
a_CQ
Post by a_CQ »
yep, old race, but problem is if you use your original old one it is the exact smae size as new, so you'd be pressing that in as well.
A piece of thicker wall steel pipe works too if you can't find the big socket. Check the plumbing section in HD or something...
Lucky for you on the hats. I've heard Coleman will do hats for you if you give them specs and what rotors you intend to use....I am yet to contact them. Oh, and appearantly they don't charge a whole lot either.
oh, and no circlips front or rear? I didn't see any when pressing out the old hubs (other than a funky abs shield thingie that looks something like a circlip behind the wheel bearing with an opening for the abs sender).
yodasfro
Post by yodasfro »
Ah the protective rings? This is a good read http://www.motorgeek.com/phpBB2/viewtopic.php?t=16822
a_CQ
Post by a_CQ »
Correct. At least on my early build there was no circlips, just ABS rings you speak of.
yodasfro wrote:Ah the protective rings? This is a good read http://www.motorgeek.com/phpBB2/viewtopic.php?t=16822
thanks for the link austin, that was very interesting reading! I'll have to watch out for when I re-assemble everything.
Gotta love holiday weekends. Bunch of progress over the last few days.
S2 hubs installed, 5 lug hats mounted on 993 rotor rings:
test fitted some wheels. The 255/40/17's fit no problem on the rear:
On the fronts the tie rods interfere but I'm expecting the KW's will correct that problem. The 225's on //S car wheels fit fine with a 5mm spacer:
044 fuel pump installed, here's the old and new:
I opted not to use the check valve, straight connection to the banjo:
relay/fuse installed
Also upgrading to a B4 90q manual climate control and dash. Got my father to help. He got a little too excited when I told him he could "remove" the digital climate control wiring :-o
bits *_everywhere_*
New dash and climate control in, perfect fit:
I'm still undecided on what to do regarding the passenger airbag. Its _almost_ big enough to fit the ecu but leaves a gaping hole in the dash. Hrm.
Manual knobs, FTW.
Unfortunately there is transmission removal in my future. My clutch (spec stage 3) is slipping and I want to get in there and replace the friction surface and install the 3+.
Looking forward to getting my subframes powdercoated so I can zip the bushings in and put the suspension together.
Marc, you've got to do something about that steering wheel. That is ugly in such a nice car!! :wink:
