another S2 conversion
varia
Re: another S2 conversion
Post by varia »
Ive cut the v-band off the volvo turbo and welded the stock k24 outlet
¯\_(ツ)_/¯
project 2226
Weld looks great - nice thread!
varia
Post by varia »
made some progress:
i had to play a lot till that cobra head was fitting
however i ordered some low profile mushroom filter, i think i will go with that.
¯\_(ツ)_/¯
project 2226
I would go cobra head and real filter like the aem dry over those crappy mushroom filters. They suck and tend to fall apart
I have run a lot of cobra heads and they work great. No restriction.
When Eric was installing his Volvo K24, he had me turn down the inlet so he could use a smaller cobra head to clear everything.
varia
Post by varia »
DE80q wrote:When Eric was installing his Volvo K24, he had me turn down the inlet so he could use a smaller cobra head to clear everything.
yes, i've read that, but its too late now. i wont remove it. maybe later
the interesting thing is, David had the same turbo, exhaust manifold, and cobra head, and he had no problem. mine was an inch longer, i had to trim from the cobra head and from the passenger side frame
¯\_(ツ)_/¯
project 2226
varia
Post by varia »
i will try to start it tomorrow.
otherwise its all together
¯\_(ツ)_/¯
project 2226
varia
Post by varia »
After installing the vems.... had to find the spark, timing, too much fuel.
Of course not much luck. so at this point i gave up. I knew i cant start it and i only can do damage.
100000x to my good friend mr. greg w. he towed my car from LA to Vegas.
Once we were at Iroz Motorsport, I had high hopes
Prof. Dr, Phd Guru Wizzard Hank started the car in 20mins.
Thank you for Collin and Josh, they are excellent guys and to Marc S. for the phone support!!!
We had a problem with my ecu, #5 injector was spraying whenever the fuel pump was on...
Hank's and Marc's skill solved the problem, again.
Car is running, and registered.
Need to adress few things before next week trip to BBQ:
Alignment, address some oil leak, weird brake sizing, maybe bad MC?
¯\_(ツ)_/¯
project 2226
varia
Post by varia »
Few more pictures, and I think im done with the car for a while.
Car runs and boost well (hitting 26psi), few minor things to be fixed (i have a new set of rubber moldings, door seal, etc) but only after the moving, maybe at the spring.
oil seal was replaced
I am debating the get an other valve cover and machine it for the red coils... I like Dave's setup
S6 seats are very comfortable
and the s6 wheel's offset is great for the cq
I have a set of fusch with a brand new winter tires, so im ready for the winter
In mid January i really wanna go back to Hank, and have him tune the car on the dyno.
¯\_(ツ)_/¯
project 2226
Grillage
Post by Grillage »
Looks great!
CURRENT
PAST
No timing belt cover?
I like my coils, got the harness from your friend Norbitron. Great quality and fit, love the look. Keeps things OEM+
Maybe I missed it, but what strut top mounts are you running?
Car looks killer Chris. Good luck with the move!
varia
Post by varia »
audifreakjim wrote:Car looks killer Chris. Good luck with the move!
Thank you Jim!
Moving always sux :)
PRY4SNO wrote:No timing belt cover?
timing belt cover was removed, so Hank could have easy access to find my timing. Time to install it back.
I know about Norbitron's harness. He is my buddy from back country.
The top mounts were made by Albert, and I ran a group buy almost a year ago
https://www.akmotorsport.net/shop/all-p ... mm-offset/
¯\_(ツ)_/¯
project 2226
How's the ride on those top mounts? Albert makes nice stuff.
varia
Post by varia »
The car is extremely stiff.
Solid top mount, aluminum subframe mount, power flex CA mount, 034 engine mount, poly sub mount.
Its a dream to corner/turn with this setup but its ends there.
¯\_(ツ)_/¯
project 2226
varia
Post by varia »
made a video today.
I hope i can make it to Hank this upcoming month.
¯\_(ツ)_/¯
project 2226
