Motronic 2.3.2 ignition cut launch control
Do It Yourself!
vwnut8392
Re: Motronic 2.3.2 ignition cut launch control
Post by vwnut8392 »
- Is it sufficient to replace the socket only for the fuel/ignition part?
yes you can replace just the timing/fuel socket.
- Its an RS2 ECU with 300kpa MAP sensor and Chiptuning.
thats perfectly fine but it would be nice to know what version software the ECU is using 8A0 907 551 B or 8A0 907 551 C.
- Is it possible to read from the old chip, modify this and write to the new Chip?
Yes you should be able to read that chip in any standard eeprom programmer. as for the chip itself being a AT27C512R thats a one time pogrammable chip. you need to get an SST27SF512 chip, their electronically erasable chips and very common.
- Where is the plug located? The photo looks like it is around the ECU? but i dont got such a plug around my ECU (Reminding installation of the WOT box) -> maybe i have to cut into my harness, do you know which PIN at ECU?
In the RS2 i have no idea where the plug lives as we never got the RS2 in the USA so i've never got to work with that car personally. the pin in the ECU connector is 39, there should be a gray/yellow wire in that position. this is following the wiring from the AAN but i figure it should be similar if not the same for the RS2. if there is no pin/wire in spot 39 in your motronic connector you can add one yourself by cannibalizing any old 55 pin motronic harness from another audi, BMW, volvo etc.
As for setting up the other ignition map on your chip i can do it for you if you read your current chip and email me the BIN file. i'll set it at the RPM you want it at and correct the checksum on the BIN for you so it doesnt throw fault code for bad eprom and such. than all you have to do is put the new BIN on an SST27SF512 chip, install it and blow some fire. dont forget to put your old chip away in a safe place incase you need it again for some reason. you dont have to touch or modify the boost chip in any way at all to do this.
So, i opened my ECU, and what i see is, there is already a solded socket for the fuel/ignition. Isnt it?
I got 2 photos, it must be the chip where's written MOT
EDIT: this chip is an Atmel AT27C512R
the MOT chip is the one you want to modify.
84 4000S quattro-AAN swapped
83 UR quattro
95 URS6 avant
95 URS6 sedan
90 90 sedan-AAN swapped
91 200 20V turbo
92 GTI VR6
92 GTI G60 X-flow turbo
86 16V jetta coupe
KevinRS
Post by KevinRS »
Okay, thats fine, thanks a lot for your help.
Unfortunately there is no label or something at the ecu case. My idea was, to read the part number with VCDS, but there only stands "T+S-Tuning" in that box where's usally the part number.
Its just for knowlege where the hex offset begins, isnt it?
Okay, i will try it by myself with these two programms. hopefully i will find the right offset because i dont know the right part number. Dont got me wrong, but i got so much ambition to try it first by myself. If it goes wrong, the option is still there, i really appreciate that! :) :ty:
Maybe i will do this on some EPROM and try different RPMs. The SST27SF512 chip is hardly to get in Germany, just found it at ebay, but location Hongkong. And i always got problems with shipping from asia.
What is your favourite EPROM/EEPROM Programmer? Any recommendations?
Best regards
Kevin
vwnut8392
Post by vwnut8392 »
KevinRS wrote:Okay, thats fine, thanks a lot for your help.
Best regards
Kevin
you can get the software part # from vag com.
I use SST27SF512 eeproms and a the willem GQ4X chip programmer.
83 UR quattro
95 URS6 avant
95 URS6 sedan
91 200 20V turbo
92 GTI VR6
86 16V jetta coupe
KevinRS
Post by KevinRS »
Okay. Mhm i used VAG COM / VCDS.
Have a look:
vwnut8392
Post by vwnut8392 »
KevinRS wrote:Okay. Mhm i used VAG COM / VCDS.
Have a look:
The attachment IMG_20150628_164401-1024x768.jpg is no longer available
They changed the info string that had the software part # in it. well the only other way to tell if its 551B or 551C is if it has the string of code for the immobilizer in it. the 551C will have immo code and the 551B wont have it.
picture of the immo code. 551B top and 551C bottom.
offset rs2.JPG (383.24 KiB) Viewed 78642 times
83 UR quattro
95 URS6 avant
95 URS6 sedan
91 200 20V turbo
92 GTI VR6
86 16V jetta coupe
KevinRS
Post by KevinRS »
Okay thanks a lot. My chip reader is on the way. I got an ECU for immobilizer. He's a photo:
With connected engine ecu starting would be allowed. But with disconnected engine ecu starting would also be allowed.
So i think the engine ecu doesnt play a role for starting, only the car-keys. In that case i could use every fitting ECU without breaking-in the ecu to the immo.
But maybe its different because ist not the original ECU and immo was disabled/not used in this ECU.
Have to wait for the chip programmer to know for sure.
KevinRS
Post by KevinRS »
So, programmer has been delivered today. Now i have read the chip.
Here is an image of Offset 00008605, i dont know what to say about the immo. Offset 0000A610 is empty.
S2 01.JPG (159.9 KiB) Viewed 78625 times
So i opend the bin file with winOLS. It found a lot of 16x16maps, but none of them begins at any Offset you have written in Post 2.
WinOLS detected AUDI S2 ECU. Dont know if its correct.
EDIT:
MOT AUDI S2 428BHP.rar
(23.15 KiB) Downloaded 2893 times
- > Added my MOT BIN-File, maybe you can find out
KevinRS
Post by KevinRS »
I downloaded your RS2 File 551B and compared it with mine, seems to be the much same:
Right is my BIN and left is your RS2
S2 02.JPG (304.4 KiB) Viewed 78624 times
S2 03.JPG (304.41 KiB) Viewed 78624 times
Please read the BIN with TunerPro. Ignition seems to be the same as OEM RS2. isnt it?
vwnut8392
Post by vwnut8392 »
its an RS2 551B file. there's some pretty decent changes in that BIN. they dont edit all ignition maps, just the main map.
83 UR quattro
95 URS6 avant
95 URS6 sedan
91 200 20V turbo
92 GTI VR6
86 16V jetta coupe
KevinRS
Post by KevinRS »
Yeah i also thought so, the other ignition maps are really late in timing. But which which map is the map i need. Simply i can copy the driving map and insert this to the other maps and and correct the ignition at certain RPM.
KevinRS
Post by KevinRS »
Unfortunately the letter carriers of DHL currently striking in Germany, so my Chips are left behind indefinitely.
I found a seller of an EEPROM in the next bigger city. Now my next question: is that chip suitable?
Its an ATMEGA8L-8PU
vwnut8392
Post by vwnut8392 »
doesnt seem like it. i only ever used SST27SF512 or atmel 27C512R. i just reread and realized the chip in the ECU is electronically erasable. if you dont mind losing not having a backup of your tune than you can erase the chip you have.
83 UR quattro
95 URS6 avant
95 URS6 sedan
91 200 20V turbo
92 GTI VR6
86 16V jetta coupe
KevinRS
Post by KevinRS »
Why do think these Chip (ATMEGA8L-8PU) isnt suitable?
What? Really? The Atmel 27C512R ist e-erasable? I just searched for the Datasheet of the Atmel 27C512R and there is written the chip is only one time programmable.
S2 04.JPG (99.14 KiB) Viewed 78569 times
vwnut8392
Post by vwnut8392 »
thats what i originally thought. the SST27SF512 is your only hope or to find more one time programmable chips.
83 UR quattro
95 URS6 avant
95 URS6 sedan
91 200 20V turbo
92 GTI VR6
86 16V jetta coupe
martin6
Post by martin6 »
Very interesting find vwnut8392, thank you very much for sharing your knowledge!
@KevinRS: Add http://www.chip-service.de to your favorites.
Günter Jäger has a good range of products for the older ECUs.
I bought some uv-erasable M27C256B and M87C257 ones and a UV eraser station too, to play around with the Audi ECUs.
Quick checkout and delivery, very friendly owner.
Additionally, the shop has a flash EEPROM AM28F512-150PC, which could also work in this ECU, I'll give that also a try.
KevinRS
Post by KevinRS »
Thanks a lot it works very well :)
vwnut8392
Post by vwnut8392 »
Be careful with it because it could do this to your muffler. this abused muffler is barely a year old :lol:. good job though kevin! now lets see a video of the car launching on it!
83 UR quattro
95 URS6 avant
95 URS6 sedan
91 200 20V turbo
92 GTI VR6
86 16V jetta coupe
KevinRS
Post by KevinRS »
martin6
Post by martin6 »
At the moment, I'm doing this mod (Launch Control with ECU Switch) to a friend's 551AA ECU too.
What I understand now is that the car will not throw flames or bang, as long as there is no wotbox installed (which I will not do).
Just for curiousity:
-Why isn't it enough to fit the wotbox without the ECU mod, why wotbox AND ECU mod?
This combination doesn't make sense to me.
-Will the car generate boost at 4500rpm with the ECU mod and without wotbox?
The car has OE turbocharger, 3" exhaust with 100cell motorsports metal catalytic converter - hopefully this will hold :-)
@KevinRS thanks for your detailed resistor info, ECU is OK :-)
martin6
Post by martin6 »
Tested today, but no luck.
I did the change in the map at 0x9594 (ECU is a 8A0 907 551AA with 8A0 907 551B software).
When giving ground to the mentioned pin on the coding plug (or ECU pin 39, double-checked that),
the car obviously does not switch to the launch control map, and revs freely to ~7000.
The software is not OE RS2 btw, it's a modified chip, checksum is OK too (I let WinOLS do the job)
Any ideas, what the reason for this could be?
KevinRS
Post by KevinRS »
Okay. No it will not generate boost without wotbox. Maybe with a really hot manifold. Important is the late ignition.
Okay, did you copied your driving map to this map (beginning at offset 9594) and then corrected the ignition timing at certain RPM?
martin6
Post by martin6 »
Yes, my map looks like this:
As you can see, my map starts at 9594, and is zeroed from 9634 to 9693.
Here the same map, with rpm factor:
Can you confirm that 551B "launch control map" is the 9594?
Maybe this is the wrong map and therefore it doesn't get active with Pin 39 to ground?
KevinRS
Post by KevinRS »
I write you a message, in german :)
KevinRS
Post by KevinRS »
@vwnut8392:
I got another question. Whats about the rev limiter. If i want to set the rev limiter to 7500rpm, no Problem with the wot box.
But i want the ignition to be late @ 7500rpm, just like the launch control.
But my table in tunerproRT ends at 7000rpm, what could i do?
Regards kevin
vwnut8392
Post by vwnut8392 »
the rev limiter in the wot box is useless to you, its not enabled when run in the global setting. what i think your getting at is you want an ignition cut rev limiter which wont happen unless you write custom code to the ecu to make it do so instead of interrupting the injector pulse. this is far more complicated than what i've done but i have looked into it.
83 UR quattro
95 URS6 avant
95 URS6 sedan
91 200 20V turbo
92 GTI VR6
86 16V jetta coupe
