George's B4 1.8t
Re: George's B4 1.8t
Just a mid pipe away from hearing how this AEB sounds through that stebro exhaust!
RS4Tech
Post by RS4Tech »
Another night of work done to the car. I got the exhaust all done. I also installed a new lower rad hose as I wasn't too happy with the first version. Finally I got the a/c done and tested that and the heat. I also got the new euro headlights installed and working.
Hybrid_Hatch
Post by Hybrid_Hatch »
OH i forgot to tell you... i found the lower rad hose i used:
RS4Tech
Post by RS4Tech »
Here is the only pic I took last night
dalspaugh
Post by dalspaugh »
Looks good!
It also looks like you are still running original springs?
'95 Audi 90Q
'00 Buell X1 Racing Stripe
RS4Tech
Post by RS4Tech »
dalspaugh wrote:Looks good!
For the moment...my new springs should be here on Tuesday so then I can finally button the suspension up
dalspaugh
Post by dalspaugh »
Are you running B3 4cyl?
'95 Audi 90Q
Hopefully! Either that or I'll be whipping up a pair of B4 coil over housing quick. Luckily I have everything.
Either way, the ralley look needs to go haha!
RS4Tech
Post by RS4Tech »
I ordered b&g springs for the 90q...I will see how the ride height looks and decide if I need to make an adjustment to my spring choice.
Post by ChrisAudi80 »
I had the same swap done last year, too! http://theprojectpad.com/viewtopic.php?f=11&t=1145
Good work, man.
RS4Tech
Post by RS4Tech »
ChrisAudi80 wrote:I had the same swap done last year, too! http://theprojectpad.com/viewtopic.php?f=11&t=1145
Good work, man.
I followed that build...it was part of the inspiration for me to do my build. Hopefully I will be driving it next weekend once I have all the suspension done.
Good work, man.
Why, thank you. :D
I was inspired in turn by NiTeCs B4 Avant Q conversion.
RS4Tech
Post by RS4Tech »
ChrisAudi80 wrote:
Good work, man.
Why, thank you. :D
That was another source of my inspiration....especially in the quattro conversion
All_Euro
Post by All_Euro »
RS4Tech wrote:...Finally I welded up my driveshaft support and got the car moving under its own power...
Curious about this as I'll be doing the same soon. A neighbour of mine said the driveshaft in his truck was out of alignment a tiny bit and vibrated... I'm thinking that's just an out of balance driveshaft. What were the things you took into consideration to get the driveshaft/supports in properly?
Cool build BTW - should be a light, peppy ride with the frankenturbo and I like how the wiring is being sorted so things will all work as they should :thumbsup:
Work - Houzz / linkedin
Play - Haldex Swap
RS4Tech
Post by RS4Tech »
I leveled the front part of the driveshaft like factory, and I designed the mounts with adjustment to it can be properly aligned side to side to eliminate vibrations. There is actually a factory procedure to align the driveshaft and it will cause vibrations if not.
All_Euro
Post by All_Euro »
RS4Tech wrote:I leveled the front part of the driveshaft like factory, and I designed the mounts with adjustment to it can be properly aligned side to side to eliminate vibrations. There is actually a factory procedure to align the driveshaft and it will cause vibrations if not.
Good idea to allow for adjustments. This factory procedure would be helpful to know...
Play - Haldex Swap
RS4Tech
Post by RS4Tech »
Got one major part i was waiting for today....
One more box away from this thing being on the road
Woohoo! Getting closer!
Just FYI: My car weighed in at 1400kg with about 80liters of E85 and those heavy leather seats.
With 250chp it will be a lot of fun. I have 4.111 final drive, so it accelerates quite well.
3200rpm at 120kmh.
RS4Tech
Post by RS4Tech »
ChrisAudi80 wrote:Just FYI: My car weighed in at 1400kg with about 80liters of E85 and those heavy leather seats.
3200rpm at 120kmh.
Wow, that sounds really good. I have driven a friends B5 with a frankenturbo on his AEB. It is surprisingly fast and very smooth, so I'm hoping for at least as much in my lighter B4 and a better flowing exhaust/larger intercooler than his car.
RS4Tech
Post by RS4Tech »
Got my euro inner tails and licence plate bracket installed today...
Now for my dilemma...in my order from across the pond I got sent the euro outer tail lights. They weren't part of the order, so they are kind of a bonus to me. They are the ones that look like they are red but light up amber. The question is do I install them or sell them? What is the market for just the outer lights for a B4? I am impartial since I do not mind the red US spec lamps.
I also got my rebuilt B4 sport short ratio steering rack from Morgen Automotive the other day. That was the last part I needed to get this car on the road...now to just get working on it so I can drive it.
Love the progress so far. I definitely appreciate you approach to the build.
I'm interested in more info on your "B4 sport short ratio steering rack from Morgen Automotive," regarding: price, turns to lock, and availability.
Thanks!
PRY4SNO wrote:Love the progress so far. I definitely appreciate you approach to the build.
Thanks!
The B4 sport has a short ratio rack from factory. jorgan is company that rebuilds them.
Nice. Always thought it was just the RS2 rack.
How much for a rebuild w/ core charge?
RS4Tech
Post by RS4Tech »
PRY4SNO wrote:Nice. Always thought it was just the RS2 rack.
$337 shipped to my door including core charge, bit they are running low on core stock so unless you have a core they are hesitant to sell them. Luckily both of my B4's came with sport racks as cores. They are 2.6 turns lock to lock opposed to the standard 3.2 turns
