Phil's 20vt 5ktq, "TurdQuat" blown up RaceCor
Re: Phil's 20vt 5ktq, Get Bent
cool, stock head and stock bore?
Stock AAN with rods and 7a cams
cool
PHILLL!! What happened man!? This is your 3b swapped 5k that bent the rod? Did you change your toon dramatically from the cfg I have of yours? Sorry for questions but I am nearly in the same power range but mainly I feel bad about this happening to you. I can't believe you blew that gasket like that with ARP hardware either! You still had the k26 too right? No upgrade that I was aware of... my gasket went the same way on the stock gasket and bolts. Familiar territory :(
Hold up, that's a stock HG. I really thought you went through the engine?
It was an unopened 3b
Yeah dude, totally unopened on I think about 200k Miles.
Blew the gasket at Cyl 3, and bent cyl 5 rod. We're thinking some sort of detonation or something on Cyl 5. Cyl 5 was covered in carbon as well, when the other 4 were daaamn clean. Compression test back before it blew told us that #5 was low already. Sooooo, it's not ALL bad.
Wow. I'd say you lasted a good while longer than I did with that similar tune/boost. Borrowed time. On to better things!
AWESOME info for the 7163. To say I've been anxious to run mine since buying one over a year ago is an understatement.
The masses request vids!!
2nd gear quick pull.
Better than nothing.
....worked for me?
Probably cause I have it unlisted i'd imagine.
Tapatalk does not like the httpS, just http
Gotcha. Fixed my own post.
Re: Phil's 20vt 5ktq, Donuts are delicious.
Fun weekend. Running a torsen center and rear now, and a TTRS Turbo. It does fun stuff like this. 300whp on 91, a good bit more on e85, with a lot more potential with a fresh clutch that doesn't slip, and maybe an intercooler that isnt from the bargain bin.
Hank must have piles of those...
Tell me more about the TTRS turbo!
Ohh boy.. I seem to have an erections now. That sounds freakin beautiful Phil. Really pulls hard up top from the symphonic sound of things
Plural thanks to autocorrect LOL
In for detailed updates
"updates"
"detailed"
"In"
looool.
"detailed"
"In"
looool.
- ringbearer
At least you got a new job
Hope it's a good one!
BBQ 2015 was pretty fun.
Alex takes good pictures.
TurdQuat needs bumpers.
First couple minutes into vegas on Friday and the driver side doors got backed into by a 2500 Duramax Chevy. Still waiting on a check from the lady...
- 12185417_454174794769540_5993198571204966993_o.jpg (247.78 KiB) Viewed 47395 times
- 11782378_454174528102900_6808815749110424669_o.jpg (207.26 KiB) Viewed 47395 times
- ringbearer
Looks way better with those flares compared to how I saw it last.
Thing is fixin to be real sexy with a rear bumper.
