Audi S4000 - Alaska
Re: Audi S4000 - Alaska
sexy stuff for sure! can't wait for vids. woo wooo
UrSobsessed
Nice! Those Iroz EM's are a work of art. They flow great too.
- Namreg Rac
Making "headway"
- image.jpg (2.15 MiB) Viewed 53130 times
Sean Haynes
Anchorage Alaska
Anchorage Alaska
Nice! Getting right at it, I like your style. Running by Monday? lol.
You will love that turbo. If you thought it was fast before, you're in for a treat. What fuel pressure regulator are you using, an AAN one? You'll need that slight bump in fuel pressure for all the fuel you can get. I was at 86% DC with a 4bar 7a and the 60lb Siemens. Oh, and are you using a bigger fuel pump? 044?
- Namreg Rac
chaloux wrote:Nice! Getting right at it, I like your style. Running by Monday? lol.
I have a new 4 bar FRP. I also got those 60lb Siemens. From what I have read the stock Bosch fuel pump will work well beyond my needs so I am just putting a new one in as well as a filter.
I have a question for you: How do you know which connections on the GTX housing are the oil supply/return and coolant supply/return? I need to get this thing oriented right and can't even figure out what hole in the turbo goes to what.
Sean Haynes
Anchorage Alaska
Anchorage Alaska
Oil inlet is the smallest and should have a restrictor fitting, oil drain is largest and needs a flange, use -10 hose at least.
- Namreg Rac
Is this the oil inlet? What is that little piece on the inside? It's not a built in restricted is it?
This is the smallest hole on the turbo
- image.jpg (1.64 MiB) Viewed 53099 times
Sean Haynes
Anchorage Alaska
Anchorage Alaska
- Namreg Rac
And then the opposite side would be the drain. It has provisions for a little flange
Sean Haynes
Anchorage Alaska
Anchorage Alaska
- Namreg Rac
Like this
- image.jpg (1.13 MiB) Viewed 53099 times
Sean Haynes
Anchorage Alaska
Anchorage Alaska
Yes, that's the inlet and drain. You need fittings like these
http://store.034motorsport.com/gt-turbo ... 20965.html
http://store.034motorsport.com/flange-o ... -male.html
http://store.034motorsport.com/gt-serie ... asket.html
- Namreg Rac
Yeah I got the kit for the lines when I got the turbo.
Sean Haynes
Anchorage Alaska
Anchorage Alaska
- Namreg Rac
Boom
- image.jpg (1.67 MiB) Viewed 53104 times
Sean Haynes
Anchorage Alaska
Anchorage Alaska
- Namreg Rac
chassis work starts tomorrow, we will see how Taco's bushings and mounts work out...
- Chassis work starts tomorrow.......
- IMG_2641.JPG (2.2 MiB) Viewed 52710 times
Sean Haynes
Anchorage Alaska
Anchorage Alaska
- Namreg Rac
Sean Haynes
Anchorage Alaska
Anchorage Alaska
- Namreg Rac
Sean Haynes
Anchorage Alaska
Anchorage Alaska
- Namreg Rac
https://www.youtube.com/watch?v=ZHdbKgq ... rSrf_AXx_g
I am an idiot... "That's a pretty good idle"
All suspension/bushings/and mounts being done starting tomorrow.
Sean Haynes
Anchorage Alaska
Anchorage Alaska
Lol
Hell yeah, looks and sounds great. As I said on the other forum, post up a log if you'd like any help tuning. Now we need some vids of full throttle!!
- Namreg Rac
It is going to be a while before I get those logs posted but will do.
Sean Haynes
Anchorage Alaska
Anchorage Alaska
PICZ OF MOUNTZ AND SUBFRAME BUSHINGZZ!!!!
- Namreg Rac
ZOONAngryTaco wrote:PICZ OF MOUNTZ AND SUBFRAME BUSHINGZZ!!!!
Sean Haynes
Anchorage Alaska
Anchorage Alaska
- Namreg Rac
Subframe bushings and tranny/diff mounts ala HERSH performance. Subframe bushing were a dream to install. 2 piece setup, awesome.
Installed a rear sway bar and replaced everything that can be replaced under the car.
Installing my coil overs tomorrow then I'll report how awesome this thing drives.
THUGLIFE
THUGLIFE
- image.jpg (2.57 MiB) Viewed 52652 times
- image.jpg (2.22 MiB) Viewed 52652 times
- image.jpg (2.2 MiB) Viewed 52652 times
Sean Haynes
Anchorage Alaska
Anchorage Alaska
Nice. Sometimes having a long cold winter can have it's benefits. My 4k was so ridiculously responsive with all the solid stuff and coilovers. Every little input yielded an output. You'll love it.
Love the handwritten L
