another S2 conversion
varia
Re: another S2 conversion
Post by varia »
Still dealing with the vacuum booster leak (new is coming) but till i did a vacuum pump test setup.
¯\_(ツ)_/¯
project 2226
varia
Post by varia »
Huston, we have good vacuum booster, brakes are super!
I have an extra good working vacuum booster (b3) if anybody need it, pm
I fixed almost everything small, bugging things, car is ready for test-track driving next week or so
Since its Sunday, gave him a nice bath:
¯\_(ツ)_/¯
project 2226
Car is looking very clean... and I love how those A8 wheels look. Think I'll swap the set from my UrS to my coupe next summer instead of getting new rubber for my RS6 reps.
Wow, that looks great!
varia
Post by varia »
After a longer break (moving, work, parting out 2 cars, overhauling two engines) finally I have time to continue to work on my cq.
Getting daily inspiration from David (hybrid_hatch) I have to address few things before the upcoming BBQ on October 16th.
I had an extra pair of urs4/6 black seats, so i modified the bottom rail a bit to fit into the coupe (thank you Brent S. for the help)
I will do a DIY pdf because the requests ive received.
Got vems, but I got some error because the flywheel pin (consulted with Marc, thank you).
So my vems went thought a surgery and got converted to work with the rear crankshaft seal/sensor.
Also sourced a good looking RS2 exhaust manifold
Next step was to get a volvo turbo (Thank you Dave) and the accessories
The volvo turbo spools quicker with the modified k24 exhaust housing then with the k26/6 housing which is bolts on.
Hank -who could do the modification- is super overloaded, so thats out of question.
I could get a already modified k24 hosing from a forum member (thank you Eric and DE80q)
Now, I have to take both housing to the machine shop (Costa Mesa R&D) and hope that he can do the modification; he is already lightened my 7A flywheel.
Right now, I have to pull my transmission or the engine/transmission combo. Since I do not have lift, only floor jacks, and got no extra help, i think i will pull both. I can install the crank-seal, drill a hole for the sensor wire, install the flywheel.
Also it will give me more room to do the exhaust manifold and turbo charger (i have 034 3" downpipe, not exactly quality work) so i have to play with the bolts.
While im there i will install a new 19 rows oil cooler and a new catch can (saikou S3-OCC) and re-routing my breather system.
I also want to install helper springs and thrust bearings, because i don't like the clicking sound...
Thats my plan till the next BBQ
¯\_(ツ)_/¯
project 2226
Dave
Post by Dave »
You'll be up and running in no time!
I've looked at those cans before, seem like a good product.
varia
Post by varia »
Mcstiff wrote:I've looked at those cans before, seem like a good product.
I think so too. I wanted a simple but good, and affordable solution. Talked a lot with JP Jnl about it, and with this, later i can upgrade it to the next level.
I removed almost everything around the engine, my local friend Nelson brought back my engine hoist so to tomorrow i will pull it out.
I've put a set of pretty beaten up set of 16" fuchs with almost new tires on, till i get my 17x8" s6 avus with 35 offset, hmmm :P
¯\_(ツ)_/¯
project 2226
Saikou makes nice stuff, lots of 944 guys use their catchcan. I'll have to order one in the future.
varia
Post by varia »
i pulled the engine out. now i can work on the exhaust/turbo swap and the crank seal/sensor
I have to really wrench on it, cos that guy, Dave he is really pushing it :D
unnamed (2).jpg (67.7 KiB) Viewed 40102 times
¯\_(ツ)_/¯
project 2226
varia
Post by varia »
Made some progress:
¯\_(ツ)_/¯
project 2226
varia
Post by varia »
I got a pretty abused set of S6 avus wheels
i had a few hours, so i refinished them
¯\_(ツ)_/¯
project 2226
90quattrocoupe
Post by 90quattrocoupe »
Wheels look good, Chris.
Greg W.
varia
Post by varia »
Looks like my flywheel and turbo housing will be done, so I can continue working on it. I hope it will be running by the end if this week.
¯\_(ツ)_/¯
project 2226
Now that's a crank trigger. Nice work.
varia
Post by varia »
Thank you Jim!
Got the flywheel back, it lost 8 lbs.
Not the biggest diet ive ever seen, but healthy enough for my setup
Re-surfaced, balanced.
¯\_(ツ)_/¯
project 2226
chappers
Post by chappers »
This looks really cool, nice work!
So is it a UK car exported? Or just the rear license plate came with rear bumper?
'91 200 20v TQ - Pearl the leggy old girl - 242k miles
'61 Austin mini - rusty barnfind racecar
varia
Post by varia »
its a usa 1991 cq. the plate came with the taillight inner section
Waiting to get my turbo housing back form the machine shop, otherwise it ready to put in:
¯\_(ツ)_/¯
project 2226
varia
Post by varia »
installed a new NTC IAT sensor, had to tap a tread
Cleaned and painted the tranny
Not much i could do....
¯\_(ツ)_/¯
project 2226
pkw
Post by pkw »
wow. just saw this. nice job man.
90quattrocoupe
I like the bracket for the crank sensor bracket. :D You might want to change the plastic zip tie out to stainless ones.
Greg W.
chappers
Post by chappers »
varia wrote:its a usa 1991 cq. the plate came with the taillight inner section
Cool, well you managed to get a 1991 'J' reg plate so it matches the year of build perfect! :-)
That's looking very spangily! How did you clean up the transmission? What product do you like to use?
varia
Post by varia »
I cleaned it with soft scrub + 3m scotch brite; rinsed it, then let dry.
I used VHT cast aluminum caliper paint, nice coverage and super fast dry time, not too sensitive for oil residue
¯\_(ツ)_/¯
project 2226
Einbilden
Post by Einbilden »
Nice work , That tranny looks like it was cast yesterday.
Mike
varia
Post by varia »
Turbo bolted on:
engine bolted on:
¯\_(ツ)_/¯
project 2226
