Re: Rubi - Carlisle 2014 Photo Dump
Loling so hard.
Oh god. :lol:
varia
Post by varia »
OMG!!! :lol: :lol: :lol:
¯\_(ツ)_/¯
project 2226
Post by glibobbo21 »
Bahahahahahahaha
Hahaha@!Q!!
Dat launchface
:lol:
hahahhahahah
Wicked... You guys are just wicked.... Is sFest really only the next gathering for us?... That's tooo far way!
OB did you see what maryland did with mary? Might have to find a beach resort… maybe casa bonita….
themagellan wrote:OB did you see what maryland did with mary? Might have to find a beach resort… maybe casa bonita….
lol... maybe...
Re: Rubi - 12.739 @111mph
After 8 runs and finally settling on 25psi tire pressure... All launches were spinning all 4 tires, the night ran out before continuing...
the slip below is at 30psi boost... My "sponser" showed up in the pit, grabbed the laptop and brought it up 32psi, but couldn't get a clean pass at that level... signs of clutch slip(I believe) became a bit more evident.
Re: Rubi - 12.739 @111.38mph
"there it is"...
A 4000 pound luxury sled that does mid 12's, me gusta mucho
UrSobsessed
Post by UrSobsessed »
So badass!
And some serious LOLz to the re-faced gif!
Nice ob. Need some stickier tires! Or clutch. Or whatever. Looks fast as fook and you're still spitting flames!
Nice. Tires and clutch are doing their job well, 1.7 is a darn good 60' time for such a heavy car. Just need to get that bitch dyno tuned for moar powar
amd is the best
Post by amd is the best »
Solid runs buddy! B5 was strong too.
Nick
'00 A4 1.8t
'91 200 20v
'91 200 20v Avant
highlander69
Post by highlander69 »
EDIGREG wrote:
That's crazy !!!
I love how all the heads pop back at the same time :lol:
The small signs of clutch slippage showing up on a few logs...
Top graph, black line, highlighted... RPM's don't irregularly ramp up erratically in this fashion after catching traction.
This is 2nd gear of that 12.73 run.
My 2 conclusions:
1) Southbend Stage 4 Dual Ferramic sucks
2) Steering rack leak can be making it's way in there making this slip as it's not a repeatable event
My Course of action in the meantime:
Drive it until it's fully worn cuz there's no way in hell I'm dropping the tranny to replace the rack only to find out that IT wasn't the cause... So I'll be enjoying it at it's current tune, work on my launch and shifting until clutch replacement time. At that point I'll do both rack and clutch.
Re: Rubi - Not Really Feeling Right ATM...
To a fellow I5 Turbo Sedan...
run was terribly off.... and now Rubi is as well...
just got done with my buddies urs4 and the injector wiring was terribly beat up in places. Had to replace the connectors and short lengths of wire on #2 and #3. Might be wiring?
wouldn't doubt it... what were the symptoms? The plug on that injector is getting current in my case... identical readings from all other connectors as well...
Wiggling the wiring would make the injector work and not work, would gain momentary contact and momentary no-contact.
If you're getting proper reading I'd switch injectors around and see if it follows the injector. If that's not it I'd say ECU, but they're all getting proper readings so wtf?
dana
Post by dana »
you can use a screwdriver to the ear as a stethoscope, and see if that injector is clicking or not, and as suggested above move the injector and see if the noise follows, also what about coils?
