Toph
Re: Jim's 07K 84 Super HX40 4kq getting close...
Post by Toph »
Much fancier though - Olde Burnsides
90 Coupe Quattro - 3b + 01e
87 4000 - future trail rig
Post by glibobbo21 »
Tim, I meant after i do some building. Engines are being built for my car, and marcs URQ(07k) today and tomorrow.
ooooo, I didn't realize Mr Marc was doing an 07k too! fun times.
things are happening. pictures are being taken
Eeeeeeeexcelleeennt. *waits in anticipation*
amd is the best
Post by amd is the best »
6 to midnight.
Nick
'00 A4 1.8t
'91 200 20v
'91 200 20v Avant
Sunday bump
audidub
Post by audidub »
Stopped by earlier, Rods were on the pistons and rings were going on.
8-)
So whose is getting built first Jim?
Mine. Well..itll be running first. Typing an update now.
So how do I start this long awaited "update"? I guess ill go in order of pics that were taken. :D
SO i got myself a stg 2 "xtreme" SB clutch. highest rated full face disc they have. Feramic/Feramic. Also being coupled with the stg 3 SB PP.
SB stg 2 extreme disc
Ryan and myself finished up the DP and 90% of the exhaust. also making the center section 3", which it was 2.5 before. Then the Van-jen clamp was finished and cold side got coated. Then the injector leads were repinned for ev1 connectors.
DP action
DP action
DP for days
DP for days
vanjen clamp final and turbo housing coated.
Injectors repinned for ev1
next installment incoming...
So Ive been dying to get more fancy parts. Thanks to Hank here are a couple Ive been missing.
some stuff Ive been watiing to get my hands on...
pan teaser
pan teaser
more tease
more tease
So what do you do with expensive custom one off parts...cut holes in them!
This was an early pan that wasnt finished(no drain plug\turbo drain)
turbo oil drain
turbo oil drain
drain plug
drain plug
Some boring stuff but all has to be done...
boring rad mounts
boring rad mounts
rad clearance to IC
rad clearance to IC
turbo drain braces
turbo drain braces
breather
breather
baffle.
baffle.
Im done for the day. Lots of progress was made and maybe I'll go snap some more pics tonight of my low miles head(28k). I removed it from my 08 07k longblock I had and prepped for installing on my now almost finished block. Heres some pics
bored to 83mm
bored to 83mm
aw theyre cute together! Marcs and mine
rods\pistons done. just rings now
voila!
voila!
yes i know the rods have loose bolts lol
thats it for now boys and girls. maybe ill get froggy and go snap some more pics tonight.
this too. shortened it at least 1/2"
for hood clearance i shortened the timing cover oil filler.
and a quick example of how simple the chain system is..
much easier than a b7 s4:-D
Re: Jim's 07K 84 Super HX40 4kq 83mm engine building:-D
Huh. That chain is super simple. Awesome.
THATS ALL I GET!?
Oooooooh oops. The rods are Integrated Engineering tuscan I beams and the pistons are JE 2168's. Tool steel 22mm wrist pins also.
Is it running yet?
nice jim - gonna be a bad ass ride
A lot of lurkers here... 100 views since noon yesterday...................................................... :zzz:
Im going out in the garage. :guns:
Matt, keep your dayjob :nuts:
Lol! Poor Jim. People just wanna hear that 07k scream! Nice welds also :)
highlander69
Post by highlander69 »
Looks awesome Jim!!!
I'm sitting patiently on the fence on this 07k stuff. I've got to say that Hank's stuff it bloody awesome so far.
Great fabrication from you and Ryan also !!.
It's going to be great. :guns:
I can't wait until Carlisle.
Cheers,
Craig
Toph
Post by Toph »
Yeeeeeaaaaaaaahhhhhhhh
