AngryTaco
Re: Taco's 4KTQ 20vt Swap: The Red Baron - DEATH TO CIS!!!
Post by AngryTaco »
I just need this thing to survive bbq. Then it gets parked and converted to vems. Not gonna reach. 425hp on cis
AngryTaco
Post by AngryTaco »
The other thing ive noticed is the vacuum fkuctuates at idles. The rpm also moves up and down by a margin Id have to say is 100rpm. This is consistent with a bad mixture. Oye
scubadave
Post by scubadave »
check your boot is on properly. these issues were always a leak of some kind between the fuel distributor and intake. I made mistakes here and there with install. Im not immune.
AngryTaco
Post by AngryTaco »
Heres whats funny. I did a massive long pull tonight. I hit 130-135 with relative ease before getting off of it. It was still pulling HARD. I couldve squeezed 140 out of it. Its like CIS hates starting but when its warmed up and running, its a bat outta hell
the pull wont be as massively long with a new upgraded turbo!!!
AngryTaco
Post by AngryTaco »
Yeah no kidding. This thing is going to scream. Im bringing the hotside by a ceramic coater tomorrow for a quote. Might as well do it all at once right?
scubadave
Post by scubadave »
did you already finish the polish?
AngryTaco
Post by AngryTaco »
No, didnt get around to it yet. I'll figure out some time to get at it. I can always do it after the ceramic coat anyways.
scubadave
Post by scubadave »
got mine good and started.
AngryTaco
Post by AngryTaco »
What did you use? Or did you just hand sand it?
scubadave
Post by scubadave »
6 inch long shank (flame) cutting burr. 60 grit tapered sanding cones, and 120 grit flapper drum. thats not done yet either. it will be a mirror if I have the time to do so. I got maad skills.
AngryTaco
Post by AngryTaco »
Well took hotside to the ceramic coater this morning. Wanted like $100 for the damn thing. Screw that Ill just polish it completely. Ex manifold was $115. Bleh.
suck it up and do it!!! it helps a ton
scubadave
Post by scubadave »
I think its a matter of time and money needed for BBQ. I will likely suck it up myself, but not right now.
AngryTaco
Post by AngryTaco »
Well the other thing I dont like is they dont polish theceramic after coating. From I have been told by a family member who owns a powdercoat shop, they are suppised to pokish the ceramic for durability. Well see
AngryTaco
Re: Taco's 4KTQ 20vt Swap: The Red Baron - LICENSE PLATES!!!
Post by AngryTaco »
YAY!!!!!!!!!!!!!!!!!!!!!!
Freakin sweet man!
Post by AudiSport4000 »
lol
AngryTaco
Post by AngryTaco »
I FOUND THE BITCH ASS VACUUM LEAK!!!!!!
stupid ass inlet boot to the turbo is torn in a place I couldnt see. Hurray for household foamy cleaners!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
AngryTaco
Post by AngryTaco »
and it still idles like crap. If it drops under 1000rpm it will die. Then its a bitch to restart it. I'm tired of this crap
EFI solves ALL problems ;)
GL!
AngryTaco
Post by AngryTaco »
Turbo getting installed tomorrow!!!!!
does it run yet
20VAvant
Post by 20VAvant »
my2000apb wrote:does it run yet
I was wondering if you had it running yet.
-2014 Lexus IS350 - SOLD
-2015 Yamaha FZ-07 - SOLD
-2005 Honda CRF230F - SOLD
which one
