Sebastian's '93 UrS4 SMURFETTE85 - Motor Burning Oil
S4Pirate
Re: Sebastian's '93 UrS4 SMURFETTE85 - Now Mostly Done
Post by S4Pirate »
Made good progress on the exhaust cutout in my post BBQ stupor
The piece that routes to the valve is all welded. Just need to fab the pipe that will bolt to the exiting side of the valve and weld a flange&tip on.
Then it's just finding I home for the switch and this is one less thing on the list :D
S4Pirate
Post by S4Pirate »
Just needs some finishing touches and wiring.
I am doing this to the 4k. Someday... lol
on my stinking phone!
S4Pirate
Re: Sebastian's '93 UrS4 SMURFETTE85 - Just The Tip
Post by S4Pirate »
All cleaned up:
S4Pirate
Re: Sebastian's '93 UrS4 SMURFETTE85 - Motor Burning Oil
Post by S4Pirate »
Well I notice the motor smoking after taking off from an idle or cold start. I have my suspicions but will try to keep from jinxing myself. Burned more than a quart in 700 miles. Running 5w40 rotella ATM. Not my usual Amsoil blend but that shouldn't make a difference on a new motor.
Leak down test this weekend. Still making great power.
Man...
I'm going to reserve my guess s well but I will say that when I self tune my car on stock compression and pump gas I'm going to run 20-23psi and THAT'S IT. Specifically for my turbo (30r .63 a/r).
Also, what's REALLY lame is that you haven't posted exhaust cutout vids yet. I am disappoint.
he's on corn so I doubt its a detonation issue. certainly wasn't on the dyno, clean pulls every time, aside from the occasional pipe trying to throw itself across my shop :) I will say, 32psi is pushing the turbo pretty hard. I'd be curious to know what the shaft speeds are at these levels....
S4Pirate
Post by S4Pirate »
It's not detonation. Car still pulls cleanly. Prob worth mentioning wills car smokes kinda like mine. I'm leaning towards turbo seal dumping it right into the exhaust but will have a little more time this wknd to see what the plugs look like, do a leak down test, and see if there's any oil in the intake tract.
When wills was smoking like that and we checked his plugs at your place, they were pretty minty so seems like we *might* have similar issues. Time will tell. He had pretty strong leak down numbers a few days before hitting the dyno so unless that was his kiss of death seems like he might be leaking some oil at the turbo as well.
Curious to see what it is.
morris400
Post by morris400 »
would we be able to see some other pics of the side exhaust, im really debating on doing it to mine. just like to see how you routed it under the car.
thanks,
Kenny
2016 VW GTI DSG Daily Driver
2001 B5 S4 Stg 3- (Gone)
