Craig's Sport quattro build
amd is the best
Re: Craig's Sport quattro build
Post by amd is the best »
Pure insanity in here. Love it.
Nick
'00 A4 1.8t
'91 200 20v
'91 200 20v Avant
ralleyquattro
Post by ralleyquattro »
Audiurq wrote:These dimple dies look familiar, I hope we don't wear them out before Martin needs them ;)
Thanks for the loan :beer:
Well.. the thickness of steel paul is using it will take couple of uses and they WILL be worn out.. :o
So.. when are you going to see your car again? Can't wait to see that floor in person!
Martin Pajak
http://www.quattro.ca
82 Audi Ur-q, SQ project
83 Audi 80 q, Euro 2-Door
85 Audi Ur-q, Euro mit 3B
91 Coupe Quattro
highlander69
Post by highlander69 »
Next on the to do list is modifying the c pillar.
For the people that don't know, the sport quattro C pillar is different than the coupe C pillar.
Both cars use the same rear window,however in the sport quattro the rear window sits at a steeper angle.
So modifications are required.
In these pictures you can see what's required to get the sheet metal to match the Carbon Fibre
sport quattro roof.
Cheers,
Craig Cook.
highlander69
A few pictures of the cutting.
c pillar modified 002.jpg (891.16 KiB) Viewed 36600 times
highlander69
Still final prep required. Grining welds etc. but you get the idea.
c pillar modified 003.jpg (1.09 MiB) Viewed 36599 times
c pillar sport 003.jpg (925.6 KiB) Viewed 36599 times
c pillar modified 005.jpg (1.12 MiB) Viewed 36599 times
highlander69
Finally my body kit was done. 8-) :D
I opted for the full Carbon Fibre version.
The hood and front grill still have to be done yet.
I'm really happy with it. Lot's of trimming to do, but I will spend the time
to make sure it fits correctly.
Cheers,
Craig Cook
highlander69
Time to get some primer on this before it goes home for the winter.
car in primer 001.jpg (958.35 KiB) Viewed 36600 times
car in primer 002.jpg (887.69 KiB) Viewed 36600 times
car in primer 003.jpg (864.91 KiB) Viewed 36600 times
car in primer 004.jpg (784.69 KiB) Viewed 36600 times
highlander69
Finally in primer
car in primer 008.jpg (1.01 MiB) Viewed 36599 times
car in primer 005.jpg (889.88 KiB) Viewed 36599 times
car in primer 007.jpg (791.39 KiB) Viewed 36599 times
car in primer 006.jpg (815.56 KiB) Viewed 36599 times
yay
highlander69
After drooling over Mike's floor on his sport quattro build, I though bollocks to this.
I spent the day cutting the floors out completely. I'm going to re- do the whole floor. It's going to
be better, and way stronger than the original sport quattro. :D
I'm also going to add box tubing like the factory rally cars, and my urq project.
Anyhoo a few pics of the day's events.
Cheers,
Craig
Toph
Post by Toph »
Very nice work. I like the fact that there's 3 of these builds going on up there between friends, and each is different in some way. Have you guys considered putting mounting provisions for the b5 shift box? I'm assuming these cars will get some sort of 01e, and with the heavy chassis modifications going on, it would be a perfect time to get away from sloppy b2 shifting.
Again, very very nice work, keep it up!
90 Coupe Quattro - 3b + 01e
87 4000 - future trail rig
highlander69
Toph wrote:Very nice work. I like the fact that there's 3 of these builds going on up there between friends, and each is different in some way. Have you guys considered putting mounting provisions for the b5 shift box? I'm assuming these cars will get some sort of 01e, and with the heavy chassis modifications going on, it would be a perfect time to get away from sloppy b2 shifting.
Thanks for the kind works. Yes 01e transmissons for sure. I'm hoping to use the factory rally car gearshift set up. Martin has one, so that is the current plan.
My floor is going to be extensively modified. This is the fun part for sure.
I started drawing up the gearshift assembly. The plan is to get it 3d printed to verify fit etc.
I've attatched a pic of the first part I drew for the shift linkage.
Cheers,
Craig
Gearstick 2.jpg (52.97 KiB) Viewed 36526 times
crimson ghost
Post by crimson ghost »
Forgive me if I've forgotten some of my Sport Quattro part history. Wouldn't this be able to be done with a 4k and a Couple GT rear as long as you didn't want the true shorty Sport Quattro ???
Thanks
ralleyquattro
Yes, but a small floor modification is needed
Martin Pajak
91 Coupe Quattro
crimson ghost
ralleyquattro wrote:Yes, but a small floor modification is needed
That is great to hear. Not sure why my dumbass didn't put that together before when I was messing with a rusty UrQ.
Sorry for the thread jack but this just gave me some ideas to actually have some sort of a Sport Q rep again one day.
:ty:
PRA4WX
Post by PRA4WX »
I would like to know more about how you are going about the Audi Motorsport shifter. 8-)
highlander69
PRA4WX wrote:I would like to know more about how you are going about the Audi Motorsport shifter. 8-)
Hopefully I will have some news about the shifter in the coming weeks.
Cheers,
Craig
highlander69
It may not look like it but I have easily over 10 hours in the floor so far.
I'm really glad I cut the floors out completely. It gives me so much freedom to build the floor the way I
want to.
I decided to use 2x1" tubing as opposed to the 2.2" tubing that I used on my urq floor. This dimension just seems
a little easier to work with seeing as I'm going to have a completely flat floor.
I also added a hump for the exhaust.
Here a a few pics of the unfinished floor. Not done yet but you get the idea.
Cheers, :beer:
Craig
quattro87
Post by quattro87 »
Looks good Craig. I think that you are on the right path as far as pulling the old out and starting from scratch on the floor. Trying to weld or otherwise join old pieces together is difficult at best. Remodeling is always more difficult it seems. Nice work. That would have been about 50hrs for me. :drool:
highlander69
Thanks John.
I can't wait to get this floor buttoned up and get on to doing the more fun stuff.
Cheers,
Craig
Amazing stuff Craig.
I'm on the fun stuff now. It's making me anxious cause I just wanna drive! Just keep plugging away :)
floor looks great!
crimson ghost
Nice work
As usual, the quality of your build leaves me floored ;)
highlander69
:D :beer:
