Posted: Mon Apr 30, 2007 7:51 am
Well Derek, I could drive it there for you... Just to help you out and all.....
:-D
https://ftp.theprojectpad.com/
Are you sure? I didn't think so, and I don't think I've seen a 10.9 stretch bolt.Wizard-of-OD wrote:you do know the camshaft bolt is a stretch bolt right?
Er, what? A 10.9 grade metric bolt can't be TTY. Otherwise it wouldn't be a 10.9. Material wise, a 10.9 is roughly equal to a Grade 8 fastener. You won't be putting a 130ksi on that bolt any time soon to make it yield.Wizard-of-OD wrote:you do know the camshaft bolt is a stretch bolt right?
cuatrokoop wrote:Er, what? A 10.9 grade metric bolt can't be TTY. Otherwise it wouldn't be a 10.9. Material wise, a 10.9 is roughly equal to a Grade 8 fastener. You won't be putting a 130ksi on that bolt any time soon to make it yield.Wizard-of-OD wrote:you do know the camshaft bolt is a stretch bolt right?
no, i didn'tWizard-of-OD wrote:you do know the camshaft bolt is a stretch bolt right?
Its a stretch bolt fergie...and it costs $1.cuatrokoop wrote:Er, what? A 10.9 grade metric bolt can't be TTY. Otherwise it wouldn't be a 10.9. Material wise, a 10.9 is roughly equal to a Grade 8 fastener. You won't be putting a 130ksi on that bolt any time soon to make it yield.Wizard-of-OD wrote:you do know the camshaft bolt is a stretch bolt right?
Author: Jonathan [ Tue May 15, 2007 7:36 pm ] Post subject:newt wrote:
Do it, especially if you plan to go the KW route.mhb_1323 wrote:that looks great, you got me thinkin about going for two piece struts now. :-)
So, that makes the bolt not a stretch, right?newt wrote:Insert ETKA image
That's what I have deduced as well. Let us wait eagerly for a rebutle.Jonathan wrote:So, that makes the bolt not a stretch, right?newt wrote:Insert ETKA image
hey sparky, you brought it upWizard-of-OD wrote:I cant believe this is even being debated?
Because its a valid point.Whenever you do an engine rebuild (at least for the VW Inline-4's) you change the following:derracuda wrote:hey sparky, you brought it upWizard-of-OD wrote:I cant believe this is even being debated?
subvertdesign wrote:Looks great so far! A few ? for you. What's the offset/width of the wheels? Which strut/hub assembly- moreso what hub offset? What are you doing for camber settings? Did you clearance fit everything with the camber setting (in the two bolts for the knuckle to strut maxed out?)
No, it's not. I won't repeat myself. Nate posted the factory manual section on it too. I always use some thread locking stuff on that bolt so it doesn't back out. This is not a 1.8t, or any other VW 4cyl. What you do for those doesn't necessarily translate to a 20v or 20v 5cyl. I have NEVER replaced the cam timing cog bolt. Including the one on the 5kq that was hit by a Jeep and broke the cog. Bolt was fine, so I reused it. That was like 4 years ago.Wizard-of-OD wrote:Its a stretch bolt fergie...and it costs $1.cuatrokoop wrote:Er, what? A 10.9 grade metric bolt can't be TTY. Otherwise it wouldn't be a 10.9. Material wise, a 10.9 is roughly equal to a Grade 8 fastener. You won't be putting a 130ksi on that bolt any time soon to make it yield.Wizard-of-OD wrote:you do know the camshaft bolt is a stretch bolt right?
