Page 12 of 45
Re: A tale of Rubí... Top Assembly Commences w/PICS
Posted: Wed Jun 19, 2013 12:51 pm
It's messed looking at the det you got vs mine. Yours goes all the way around the piston, mine just melted one spot away. I wonder about those pistons of mine...
on my stinking phone!
Posted: Wed Jun 19, 2013 12:53 pm
by mushasho
chaloux wrote:HEY THAT LOOKS LIKE DET, JUMP ON THE DET TRAIN WOO WOOOOOOOOOOOO
Or did the hg fail through cylinders? Can't see shit on my phone.
Sent from my Nexus 4 using Tapatalk 4 Beta
Woooohoooooo,!!!! I do love how subtle it was for me tho, it was gradually losing power ect.... Still started up and ran, albeit with a rough idle of course...
EDIGREG wrote:That is some bad detonation. Whatever you do, don't run that same tune on the new motor.
What do the rest of the cylinders look like?
Yeah, definitely needs to be retweaked for this round... I'll get close ups of the others, but they look good and when I diagnosed the issue comp and leakdown were perfect on all but cyl 4
Hank wrote:ouch! I bet that t04e was scooting around.
It really was tho, lol
Posted: Wed Jun 19, 2013 1:08 pm
by Hank
chaloux wrote:It's messed looking at the det you got vs mine. Yours goes all the way around the piston, mine just melted one spot away. I wonder about those pistons of mine...
His just looks like it was gradually detonating. Yours looks like it was majorly detonating, thus the reason it attacked the one spot.
Posted: Wed Jun 19, 2013 1:21 pm
by EDIGREG
If it is only on #4, there may be an issue with that injector. I'd suggest having them cleaned/balanced if you're re-using for the new build
Posted: Wed Jun 19, 2013 1:40 pm
by themagellan
Yikes! I'm glad you're changing over all of the oil cooler stuff too - really make sure those lines are cleaned out well in case you have any yummy detonated reese's pieces floating around there
This thing is going to be a rocketship!!
Posted: Wed Jun 19, 2013 2:43 pm
by mushasho
themagellan wrote:Yikes! I'm glad you're changing over all of the oil cooler stuff too - really make sure those lines are cleaned out well in case you have any yummy detonated reese's pieces floating around there
I has sum new oil coolage in my possession....
Posted: Thu Jun 20, 2013 1:39 pm
by mushasho
A look of a Mustang Tranny mount used as a C4 motor mount pic... Not my car...
- uploadfromtaptalk1371752939967.jpg (85.74 KiB) Viewed 33596 times
- uploadfromtaptalk1371753494843.jpg (74.7 KiB) Viewed 33596 times
- uploadfromtaptalk1371753551385.jpg (83.08 KiB) Viewed 33596 times
Posted: Thu Jun 20, 2013 1:42 pm
by EDIGREG
Got mine to both line up pretty easily. Note that the bolts they give you with the mounts are not long enough.
Let's see some pics of the underside of the passenger mount...it looks like the mount is not seated all the way on that side?
Posted: Thu Jun 20, 2013 3:38 pm
by themagellan
Not his car I think he said...
Those look so odd in that area. OB let me bring you a cordless drill and some Canadian made hockey pucks with 1/16th thick rubber washers
Posted: Thu Jun 20, 2013 4:19 pm
by EDIGREG
Yeah, I read that, doesn't mean he can't get pics of whoevers car it is
Posted: Thu Jun 20, 2013 5:40 pm
by mushasho
by mushasho
- uploadfromtaptalk1371768040255.jpg (76.67 KiB) Viewed 33576 times
- uploadfromtaptalk1371768026583.jpg (74.7 KiB) Viewed 33576 times
Posted: Fri Jun 21, 2013 12:04 am
by Hank
What is wrong with those pictures? They look like they will bolt up fine?
The Mustang mounts are virtually identical to the audi mounts in terms of height and location of holes. If the mustang mount looks like that, so will the audi mounts.
Posted: Fri Jun 21, 2013 6:44 am
by mushasho
It's the corner square edges of mount... If I understand it correctly, in order have it fit trimming is needed to fit in the rounder housing to get the holes aligned.
Did you get that test mule c4 in yet? I'd be curious what you find...
Posted: Fri Jun 21, 2013 8:00 am
by EDIGREG
Driver's side bolts in, you only have to trim the corners of the bracket since the mounting surface is not flat.
On the passenger side, the mount does not fit into the fork on the frame rail - it is the only thing we can't see in the photos because it's blocked by the arm coming off the block. You can bolt one side in, but then the other side won't pivot in far enough. Either grind the mount or grind the fork. You also have to trim the corner of the rearward bracket on that side as well.
Posted: Fri Jun 21, 2013 12:39 pm
by mushasho
And then there was the one item that could've saved me 2grand... For now anyhow...
http://www.034motorsport.com/turbocharg ... 23817.html
Posted: Fri Jun 21, 2013 12:46 pm
by EDIGREG
how would that save you 2k?
Posted: Fri Jun 21, 2013 1:13 pm
by mushasho
EDIGREG wrote:how would that save you 2k?
Mounting it up to the side of the motor...
Think IMS header, Downpipe and wastgate combo
Posted: Fri Jun 21, 2013 1:29 pm
by EDIGREG
well... then you wouldn't have a beautiful, highly efficient equal length manifold and an awesome wastegate to go with it.
Posted: Fri Jun 21, 2013 1:56 pm
by mushasho
EDIGREG wrote:well... then you wouldn't have a beautiful, highly efficient equal length manifold and an awesome wastegate to go with it.
With leak free vBand flanges to boot... The stock wastegate probably would've been fine at my 30+psi goal though
Posted: Fri Jun 21, 2013 1:58 pm
by EDIGREG
Yeah, vbands are nice.
The wastegate would have been OK, but it is exhaust volume, not pressure that makes a difference. Too much volume for the wastegate and you won't be able to keep boost under control. Plus the Tial unit is really really nice.
Posted: Fri Jun 21, 2013 2:35 pm
by themagellan
Saw this in the morning and immediately thought ofyou haha.
Looks like only the 58mm and a few others fit?
Posted: Fri Jun 21, 2013 3:06 pm
by mushasho
The popular ones...
Posted: Tue Jun 25, 2013 9:49 pm
by mushasho
Out with the old...
- uploadfromtaptalk1372214454330.jpg (91.61 KiB) Viewed 33497 times
- uploadfromtaptalk1372214431608.jpg (82.25 KiB) Viewed 33497 times
- uploadfromtaptalk1372214417322.jpg (74.46 KiB) Viewed 33497 times
Posted: Tue Jun 25, 2013 10:04 pm
Keep going....
