Page 2 of 8
Re: Andy's 91' 80q
Posted: Mon Dec 25, 2017 2:23 pm
by rennenmsports
AKMS avoided saying anything about eliminating the snubber mount. Just to reinforce the transmission tunnel and ditch the front transmission mounts. I’m opting to utilize all the mounts including the snubber
Re: Andy's 91' 80q
Posted: Mon Dec 25, 2017 8:57 pm
by rennenmsports
Hey guys. I’m sitting here pondering how to go about doing up the tunnel. Is the tunnel one layer of sheet metal or two? I’ve got an idea but it’s easier if it’s one layer where the 4 holes need to be drilled.
Re: Andy's 91' 80q
Posted: Tue Dec 26, 2017 12:41 pm
by vt10vt
I've run a couple different setups without a snub. My '89 20vt Avant used mustang trans mounts for motor mounts and no snubber. Didn't make a ton of power but I used to launch the shit out of it constantly and never saw any signs of anything moving.
More recently I ditched the snub in my 1.8t B6. This thing doesn't make much for torque, but it made 330whp in this video. It uses homemade semi-solid (hockey puck) engine mounts, stock single trans mount, and has very little engine movement:
I honestly think the snub is only really there so that they could run comfortable (super soft) engine mounts. You might need it if you're shooting for the moon power-ways, or are planning on tracking the car REALLY aggressively, but even then I'm not sure it's really necessary.
Re: Andy's 91' 80q
Posted: Thu Dec 28, 2017 9:31 pm
by rennenmsports
Well. It’s on
And the vacuum manifold
Re: Andy's 91' 80q
Posted: Sun Dec 31, 2017 6:20 am
by Audi Tech's Mom
Nice! So that's where that fancy mount goes that we gave you for Christmas! Now I know where it goes and how things are coming together!
Mom
1970 Opel GT 1900 4-speed :)
Re: Andy's 91' 80q
Posted: Sun Dec 31, 2017 2:59 pm
by rennenmsports
Hahahaha
The infamous spaghetti
Re: Andy's 91' 80q
Posted: Sun Jan 14, 2018 11:59 am
by rennenmsports
Well shes going back together
Re: Andy's 91' 80q
Posted: Fri Jan 19, 2018 2:28 pm
by Marc
I have nothing to add, other than its pretty awesome that your mom just commented on your project thread. and buys you car parts for christmas.
Carry on.
Re: Andy's 91' 80q
Posted: Tue Jan 23, 2018 2:37 pm
by rennenmsports
Wow! Thank u! My parents are wonderful people. I’m glad I have their support in this. My project wouldn’t have been possible with out them. Thanx again Marc! I’m going to be getting your VEMS ECU at some point for this project. Just a heads up! ;)
Re: Andy's 91' 80q
Posted: Tue Jan 23, 2018 5:16 pm
by rennenmsports
Well. I regret to say that this 01E mount from AK Motorsports does not fit this car at all. It's geometry is off to the point that it will not go up into the trans tunnel with out banging in the tunnel from underneath the car. They told me that I have to fabricate and reinforce the tunnel. After that no more response. I don’t see me beating the tunnel in and then cutting and welding it back together. If it fit into place so I can mark it then fabricate that’s one thing. :huh:
Re: Andy's 91' 80q
Posted: Wed Jan 24, 2018 12:34 pm
by the german
On the website they do say that it is not a bolt-on and requires fabrication on the chassis side to make it work, but that message is somewhat understated in the description. You may need to cut a slice out of the tunnel, bolt the trans in place using the forward mounts, then fabricate the replacement tunnel section w/ mounting points for the AK rear mounting plate. HTH
Re: Andy's 91' 80q
Posted: Wed Jan 24, 2018 6:24 pm
by rennenmsports
Yes. I agree. I’m going to save it for a later date. It bolts to my 01E just fine so I can make it work. I thought it fit better then I anticipated. I’m trying to get it to run without making it a full race car. But I have a good feeling it’s going to be sooner then later. I never seen anything like that mount before so I thought I’d give it a whirl.
Re: Andy's 91' 80q
Posted: Fri Jan 26, 2018 7:51 am
by rennenmsports
V8q battery cables and junction box r going in
Re: Andy's 91' 80q
Posted: Fri Jan 26, 2018 6:25 pm
by rennenmsports
Took a little convincing but.....
Re: Andy's 91' 80q
Posted: Sat Jan 27, 2018 12:43 am
Is that the firewall AC hardline fitting you've routed the wiring through?
Re: Andy's 91' 80q
Posted: Sat Jan 27, 2018 10:59 am
by rennenmsports
Yes. I had it routed that way in the beginning but changed it to the grommet for the seat belt cable
Re: Andy's 91' 80q
Posted: Sat Jan 27, 2018 8:19 pm
by rennenmsports
No one got hurt and nothing got broken! Good times
Re: Andy's 91' 80q
Posted: Sun Jan 28, 2018 5:10 pm
by mrdeye
:thumbsup: :beer:
Re: Andy's 91' 80q
Posted: Tue Jan 30, 2018 9:25 pm
by rennenmsports
Anyone know what size vacuum line goes to the VEMS urs4/6 ecu? My Wagner I.M. hose barbs are 3.67mm at its lowest point. I suppose it’s 3.5mm then.
Re: Andy's 91' 80q
Posted: Tue Feb 06, 2018 6:20 pm
by rennenmsports
Found a John Deere tractor clevis for my clutch master
Re: Andy's 91' 80q
Posted: Tue Feb 06, 2018 9:06 pm
by mrdeye
Merica!!
Re: Andy's 91' 80q
Posted: Wed Feb 07, 2018 4:50 pm
by rennenmsports
intercooler came :rofl:
Re: Andy's 91' 80q
Posted: Tue Mar 06, 2018 7:44 pm
by rennenmsports
A little smaller than I anticipated but really is a nice piece
Re: Andy's 91' 80q
Posted: Wed Mar 07, 2018 7:40 am
by maxnadri
This project is really coming along, I like what you are doing, the transmission tunnel you left it? No slicing and stretching it out a tiny bit? Is that a stock 3b 20v intercooler? What are your HP/TRQ goals? This looks like a really fun project, I have enjoyed watching.
Re: Andy's 91' 80q
Posted: Wed Mar 07, 2018 7:17 pm
by rennenmsports
maxnadri wrote:This project is really coming along, I like what you are doing, the transmission tunnel you left it? No slicing and stretching it out a tiny bit? Is that a stock 3b 20v intercooler? What are your HP/TRQ goals? This looks like a really fun project, I have enjoyed watching.
Awesome! Thank you! I left the tunnel alone for now. Maybe after its up and running I'll consider installing the rear mount. The intercooler is from Wagner Tuning. Its the short path. They sell just the cooler now. Before I think you had to get the entire $990 kit. Due to the length of the cooler inlet and outlets its not going to sit dead center. Maybe a 1/2'' off. If I was to remake the power steering pump pulley bracket to hug the block tighter it would be able to have the room. My goal is about 450-500hp with the egine the way it is inside. I want the chassis built for much more then that though.
