Page 67 of 71
Posted: Mon Oct 31, 2016 8:44 pm
by 88a5tq
quite right. Guess ill figure out the thread tomorrow
Posted: Tue Nov 01, 2016 4:26 pm
by 88a5tq
Weep, its an m12 x 1.50 thread of which I'm holding the tap for. I'm going in..
Posted: Tue Nov 01, 2016 8:43 pm
Go for it!
Posted: Wed Nov 02, 2016 8:42 am
by 88a5tq
I'm not ecstatic about the fact that giant pieces of green looking, cured threadlocker came out on the tap. I went as far as finger tight got me only. No wander they were not magnetic! I can only assume the green is the factory installed OE blue loctite equivalent as I specified blue as a substitute in my instructions
I could maybe see the size of the pieces blocking a head galley and leading to my suicide in the future. Considering making them clean out the threads like they probably shouldve done already!
Posted: Thu Nov 03, 2016 8:49 pm
by 88a5tq
Went to the gas station!! Only problem is the oil pressure sender is making the gauge read way past 5 bar like its pegged but it reads 0 bar with key in run position before starting the engine. As soon as it starts it pegs itself. I tried switching the wires and this way seems more normal than the other way's behavior. The old sender does the same crap lol. I didnt drive it long enough to see the pressure drop to the usual 2 bar.
Posted: Fri Nov 04, 2016 9:38 am
by 88a5tq
Posted: Fri Nov 04, 2016 10:52 am
by scubagli
5 bar+ on cold oil seems normal to me. Every euro car I've owned that had an oil pressure gauge did that. My tdi would make 90 psi until engine came up to temp, then stay around 20-30 psi depending on rpm.
Posted: Fri Nov 04, 2016 1:11 pm
by 88a5tq
Thanks scuba Steve
I drove to my brothers house on the other side of town without issue but the gauge stayed pegged even when warm
I'll order the new one today but it'll be OE this time. I think the FAE might be DOA?
Posted: Fri Nov 04, 2016 3:26 pm
by yodasfro
That will also happen when the two wires are reversed on the sensor.
Posted: Fri Nov 04, 2016 4:15 pm
by 88a5tq
Thanks austin. What's odd is when I switched the wires the warning would sound and the pressure reading would peg above 5 bar like the OE sender when it seems to be functioning. So to sum up, when the wires appear correct on both:
OE- zero with key on, pegged above 5 when running
FAE- slightly above zero with key on, pegged above 5 with autocheck warning
Posted: Sun Nov 06, 2016 7:54 pm
by 88a5tq
Ah jeez. I have a confusing update.
OE- zero with key on, pegged above 5 when running but now very randomly sounds the oil buzzer.
FAE- now AT zero with key on, stays at zero while running regardless of load or rpm lol
Posted: Tue Nov 08, 2016 10:32 am
by 88a5tq
GTJeff wrote:Have you verified that the check valve isn't crushed?f=10&t=40901[/url]
Man why didn't you ask for your cookie?! You earned it and I forgot
Posted: Mon Nov 14, 2016 7:21 pm
by 88a5tq
How TF do I keep buying new defective items!? The FAE oil pressure sender was also defective. OEM VDO sender worked as soon as I installed it.
Posted: Wed Nov 16, 2016 9:38 am
by 88a5tq
I'm blown away by how healthy the motor runs now. I run the holsets to 30 psi with zero oil in the catch can!
Posted: Fri Nov 18, 2016 1:12 pm
by 88a5tq
Just this week alone:
One defective IACV from eBay
One defective m1-205 oil filter Frome Autozone (had a rattle internally)
Posted: Fri Nov 18, 2016 11:05 pm
I quit buying non oem stuff a while ago for this reason!
Posted: Mon Nov 21, 2016 2:26 pm
by 88a5tq
so i went out to do donuts with lots of boost and the resulting log was quite rich overall! tune is excellent during other driving scenarios including boost though . only time it gets "weird" is between shifts. heres the log file. i probably had the heat on which ALWAYS makes lambda off during inconsistent throttle intervals. does this seem reasonable?
i disabled all the rich decal settings that were active during the breakdown so break in would be safe
Posted: Tue Nov 22, 2016 9:51 pm
by 88a5tq
- IMG_20161122_214619.jpg (3.06 MiB) Viewed 40880 times
Is this reasonable you guys think? 0.79 lambda at 30 psi seem too rich or good? This is with the new direct port meth injection spraying. Feels very healthy at that afr.
Posted: Thu Nov 24, 2016 12:06 pm
by 88a5tq
Marc says this all looks good for lambda target. Happy Thanksgiving everyone!
Posted: Sat Nov 26, 2016 11:59 am
Yeah doesn't look bad to me. Happy Holidays
Posted: Sat Nov 26, 2016 12:11 pm
by 88a5tq
Thanks man you too
Posted: Sat Nov 26, 2016 2:23 pm
by 88a5tq
Real quick I wanna ask everybody running over 25 lbs of boost, are you all running bosch F5DPOR plugs? Did anymore go one step colder? Just curious
If you didn't and you gap your own plugs, what gap please? TIA.
Enjoy time with your families.
Posted: Sat Nov 26, 2016 3:13 pm
Posted: Sat Nov 26, 2016 4:38 pm
by 88a5tq
Oh ya that's a nice reference for sure! Thanks
Posted: Wed Nov 30, 2016 2:15 pm
by 88a5tq
- IMG_20161130_141234.jpg (3.97 MiB) Viewed 40741 times
droooool
