Page 7 of 8
Re: Nick's 1991 200qa "Project" - "R4CEW4GN"
Posted: Mon Oct 12, 2015 8:35 am
Why do you need the engine back in and running? As long as the fuel lines, fuel rail are all intact you can do it by output test in VEMS with fuel pump on (which you can jump in the fuse panel, at least in C4s). Even stock injectors... Run each for a minute and measure output after. Hopefully you see less fuel out of #3.
Posted: Tue Oct 13, 2015 6:45 pm
by amd is the best
That only opens the injector 100%. I need rpm signal to actually simulate the injector driver working at different duty cycles. Unless there's a way to tell it to output a specific duty?
Posted: Tue Oct 13, 2015 8:03 pm
Hmm yeah that's right. I don't think so but I'd have to look into that.
Posted: Tue Oct 13, 2015 8:24 pm
There's definitely a way, but maybe not with vems. If I was there I'd try to set up a testing package for it with hardware and software. It's not very complicated from a hardware standpoint. Pretty much just a relay and a dac.
Posted: Tue Oct 13, 2015 8:39 pm
by Marc
Posted: Wed Oct 14, 2015 2:31 am
by amd is the best
I actually have an old megasquirt stimulator. Maybe I can get that thing to work somehow. I figure just doing the testing running will also work since I'm getting closer. Engine is now out of the sedan.
Posted: Wed Oct 28, 2015 7:31 am
by amd is the best
Ok guys, I need some help. Avant is up and running well which I am very happy about. I am being extra super careful this time around with tuning and some things aren't making sense to me. Wideband and dutycycle on the injectors would indicate I am running WAY rich (I am playing it very safe to ensure no molten aluminum happens) and the plug insulators are white like brand new. No signs of detonation.
Background:
VEMS
R8 red coils
BKR7E plugs
Deka 870's @ 3bar currently
Walbro 450 F9000267 in tank
IROZ K26/EFR6758 kit
Stock intercooler
It's tuned to ~24psi on 93 octane right now. I have the AFR hanging around. .72-.74 and the injectors are around 50% when power comes on and up to about 75% top end. Between the two (AFR/duty) it would indicate a very rich mixture. I'm also watching EGT at the turbine inlet. During a 3rd gear pull it ramps from 560c to 820c. Plug insulators are icy white like brand new. Around the threads are black. All plugs are consistent to each other looking nearly identical. No audible indication of detonation nor visual on the plugs either.
I have swapped WB02's and both were recently calibrated as well.
Timing is SUPER conservative hitting 7deg boost onset and 12deg top end.
As scary as it sounds, I never really read plugs before on my other cars. Not nearly as carefully as I have been now anyway. So I can't even confirm what a proper big turbo plug would/should look like.
I'm nervous to lean it out to my normal target of .79-.80 with fear of what happened last time. Especially with how the plugs are reading.
Insight? Thoughts?
Posted: Wed Oct 28, 2015 9:41 am
My thoughts would be to back boost down for a while. Your description of the plugs is good, but pictures wouldn't hurt. Does the power level seem appropriate for the boost you're running currently? Were you ever able to test injector outputs? I'd be scared to run it hard before doing that.
If it were me, I'd back boost down, but lean it out and read plugs. Things won't be nearly as susceptible to melting at lower boost and the plugs should be easier to read. Where is the timing mark on the plug ground strap after a hard pull? Remember, you can't really read plugs properly when they've been run in multiple conditions.
Posted: Wed Oct 28, 2015 1:22 pm
by amd is the best
I think that will probably be the best plan. Run it at the current wastegate spring (~13psi). Lean it back to .79ish and see how the plugs look with some miles. From what I gather, on E85, plugs don't turn brown ever. Just always look new. There is probably still some E85 in the tank from back in the spring when it blew up though quite diluted now. I'll keep putting miles on it with the boost low. Man she scoots though! I'm seeing 23-24psi around 3500-3650 and it's feeling just like the sedan used to if not better!
Posted: Thu Oct 29, 2015 3:58 pm
by themagellan
amd is the best wrote:I think that will probably be the best plan. Run it at the current wastegate spring (~13psi). Lean it back to .79ish and see how the plugs look with some miles. From what I gather, on E85, plugs don't turn brown ever. Just always look new. There is probably still some E85 in the tank from back in the spring when it blew up though quite diluted now. I'll keep putting miles on it with the boost low. Man she scoots though! I'm seeing 23-24psi around 3500-3650 and it's feeling just like the sedan used to if not better!
Yes, the carbon build up makes that 'Coffee' color if i'm not mistaken, so with e85 it's not really something you'd want to do with an eye. I've seen it takes a while as well to become fully colored too.
What you should be doing if you want to really read the plug, is get a magnifying glass and look at that. Specifically you are looking for pitting in the sparkplug electrode, that really can only be seen with a magnifying glass.
Glad to see you are taking it easy! Set up is killer.
edit:
Video would be cool
What FPR are you using?
Is that a Wagner Exhaust manifold - I missed that part
Posted: Tue Nov 03, 2015 5:43 pm
by amd is the best
Quick clip:
Currently on a stock FPR only because my 7A one sprang a leak. New one is in possesion and I will change that out at some point.
eBay RS2 manifold.
Posted: Tue Nov 03, 2015 7:59 pm
by themagellan
It sounds so healthy. The spool is really impressive even in second gear @ 20mph
Posted: Tue Nov 17, 2015 2:11 pm
by amd is the best
Posted: Tue Nov 17, 2015 7:59 pm
by k2exoman
The R4CEW4GN sounds awesome!
Posted: Wed Nov 18, 2015 1:28 am
Heck yeah
Posted: Wed Nov 18, 2015 8:26 am
by amd is the best
Posted: Wed Nov 18, 2015 8:07 pm
I honestly just do this so I can watch them without turning on my computer. No S after http please :)
Posted: Fri Nov 20, 2015 9:29 am
by amd is the best
Hmm. Seems to work fine on my phone...
Posted: Fri Nov 20, 2015 11:36 am
Looks like you're using a browser? Matt's talking about tapatalk users.
Posted: Fri Nov 20, 2015 2:09 pm
by themagellan
app needs 'secure' connection - I hope there is more flogging posted soon
Posted: Fri Nov 20, 2015 5:39 pm
Yeah from within Tapatalk specifically.
Posted: Sat Nov 21, 2015 9:19 am
This is what we see:
Posted: Sun Nov 22, 2015 6:39 am
by AudiQuattros
Passed!
when ever I blow in to your wagon ... 400-500whp
Posted: Sun Nov 22, 2015 8:49 am
by amd is the best
016 = boom last night.
She was tired though. When I got the car there was no fluid in the thing per the usual input shaft seal leak. Changed the seal and fluid but it was too late. It made some serious whining that would change in pitch based on the gear/speed. Def final drive related.
Last night just rolled on it in 3rd, BANG and revved up like in neutral. Clutch feels normal and goes into all the gears fine. Willing to bet it's the pinion or ring gear on the front diff. Either way I'll be pulling it apart on my days off (tomorrow and tuesday) and dropping in the spare unit. The spare is a very low miles unit that was in excellent shape when I had it in my sedan before the 6 speed swap. It does need a 5th gear synchro though. So I'll be pulling that apart and replacing that as well.
Posted: Sun Nov 22, 2015 12:27 pm
Lol. Party time. Do you have the 5th synchro?
