Page 7 of 8
Re: Andy's 91' 80q
Posted: Sat Mar 04, 2023 10:51 pm
by rennenmsports
- 3880B17E-C611-4865-8002-9658234DAFDF.jpeg (65.38 KiB) Viewed 52207 times
Urs front hub with an E36 wheel bearing. Had to take about 3mm off the knuckle in a cone shaped angle. it’s definitely a really tight fit
Re: Andy's 91' 80q
Posted: Sun Mar 05, 2023 12:08 pm
by rennenmsports
- A6612661-0261-4428-B434-5D0ED4EB53C0.jpeg (106.21 KiB) Viewed 52188 times
Bruce lee’s 1 inch punch to spread the transmission tunnel for the 01E 6 spd
Re: Andy's 91' 80q
Posted: Sun Mar 05, 2023 12:24 pm
by rennenmsports
- B0D75535-5CB9-4EBA-9DF5-628798B9B987.jpeg (131.06 KiB) Viewed 52185 times
It’s getting really close. Just need a front brake set up. If anyone has one for sale please pm me
Re: Andy's 91' 80q
Posted: Thu Mar 09, 2023 7:00 am
by rennenmsports
- CF9C3DED-512F-4777-A2C2-B562E0C85109.jpeg (69.07 KiB) Viewed 52039 times
I used a counter sink bit to be able to use a flat headed taper bolt so I can install a -10an banjo fitting for the transmission cooler
Re: Andy's 91' 80q
Posted: Fri Apr 07, 2023 5:36 pm
by rennenmsports
- 18FB8EC4-FCC2-4933-9C03-8579D24904E2.jpeg (159.74 KiB) Viewed 49176 times
Rebuilt prop shaft center support
Bearing from McMaster carr 4668k295 works
Re: Andy's 91' 80q
Posted: Fri May 26, 2023 5:02 pm
by rennenmsports
-10 lines for the transmission cooler
- 70682280128__A94618B9-0B8E-41DB-B75A-29EE7C948027.jpeg (104.79 KiB) Viewed 46815 times
- 70682279011__70E6D2CA-F54F-420E-B965-1336A19FA256.jpeg (106.8 KiB) Viewed 46815 times
Re: Andy's 91' 80q
Posted: Fri May 26, 2023 10:47 pm
by DE80q
Does it move on its own power yet?
Re: Andy's 91' 80q
Posted: Sat May 27, 2023 7:23 am
by rennenmsports
DE80q wrote:Does it move on its own power yet?
Almost waiting on a T fitting to finish the engine oil cooler lines. I was bleeding the brakes when the master decided to go out. Glad it did at home. It is original. Also rear sway bar end links and a DIY alignment so I can get it to an alignment rack. But that doesn’t keep it from moving on its own. The last thing is to tune the VEMS. I’m all the way down in south Florida so I’m hoping Marc can help remote tune it at some point. No idea what that entails.
Re: Andy's 91' 80q
Posted: Sun May 28, 2023 7:21 am
by rennenmsports
I figured out a simple way to strengthen the push rod on the clutch master. I just stacked up nuts and grinded one down to meet the necessary adjustment
- 70507743513__763B045D-23F9-4275-89B9-EE3973082101.jpeg (116.93 KiB) Viewed 46761 times
Re: Andy's 91' 80q
Posted: Sat Jun 03, 2023 2:49 pm
by rennenmsports
She’s ready to tune
Re: Andy's 91' 80q
Posted: Thu Jun 22, 2023 8:46 am
by rennenmsports
- IMG_5161.jpeg (107.11 KiB) Viewed 46033 times
Re: Andy's 91' 80q
Posted: Thu Jun 22, 2023 9:07 am
by rennenmsports
It started misfiring pretty bad. It has Amazon coils. So I ordered Okada coils for the ttrs in hopes that it stops the issue. I also previously relayed the coils with a 50A/30A relay. It was getting pretty warm so I ordered a 70A replacement. When everything gets here we’ll see if the problem goes away and we can finish tuning it. I got the hood on. Had to drill holes in it for the exhaust. Fortunately I have a new one in Delaware.
Re: Andy's 91' 80q
Posted: Sat Oct 28, 2023 5:40 pm
by rennenmsports
- 72014647413__3BF4DD15-126C-4A2A-B03B-3600360E62D6.jpeg (117.42 KiB) Viewed 39322 times
To be continued
Re: Andy's 91' 80q
Posted: Fri Apr 12, 2024 12:00 pm
by rennenmsports
The new coils solved the issue only it lost a lot of compression due to piston ring failure. I finally am able to start removal and disassembly of the entire engine this time.
Re: Andy's 91' 80q
Posted: Mon Jan 20, 2025 9:30 am
by rennenmsports
She’s all back together again. So I called Marc for a remote tune. Over the internet and through the computer it started right up. Thank you!!
Re: Andy's 91' 80q
Posted: Mon Jan 20, 2025 11:54 am
by Marc
rennenmsports wrote:She’s all back together again. So I called Marc for a remote tune. Over the internet and through the computer it started right up. Thank you!!
any time. its what we do.
Re: Andy's 91' 80q
Posted: Fri Jan 24, 2025 9:42 am
by rennenmsports
After starting it for the first time the second time around. Had a loose oil cooler hose and a leaky freeze plug. They are now fixed. Gotta get a plate and registration and I should also hook up the electric power steering pump. Not sure if that affects tuning. It is more of a load on the engine. I’m going to idle it more to make sure it’s ready as much as I can.
Re: Andy's 91' 80q
Posted: Mon May 05, 2025 4:24 pm
by rennenmsports
Everything is great 100 or so miles later. I needed a vacation from it. It turned into an obsession again and now I can relax. It’s back to it now.
First is the power steering doesn’t work. I used a mini cooper electric pump that’s not coming on.
Just ordered one today. This weekend I’ll finally be able to really drive it
Re: Andy's 91' 80q
Posted: Mon May 05, 2025 5:05 pm
by DE80q
I'll believe it when I see it!
I shouldn't say though, mine hasn't moved in 2 years haha.
Re: Andy's 91' 80q
Posted: Tue May 06, 2025 7:58 am
by rennenmsports
DE80q wrote:I'll believe it when I see it!
Haha. It’s been a 18 year long project. It’s hard to believe myself. So long my mind still doesn’t register that it’s available to use
Re: Andy's 91' 80q
Posted: Mon Nov 03, 2025 1:28 pm
by rennenmsports
Hello again. It’s been a long time. I decided to keep it. Too sentimental. The piston rings went. I’m going to be able to get a short block from Marc in about 6 months. Now that I know which turbine housing I’m going to use I can make the exhaust and intake as well.
Re: Andy's 91' 80q
Posted: Thu Jan 08, 2026 8:27 am
by rennenmsports
- IMG_0077.jpeg (3.39 MiB) Viewed 4613 times
I pushed her back into the garage on the first. Happy new year everyone. for the third time around. This time I’m getting a short block professionally built. Didn’t have much luck the first two times. I’ve gotta make the intake and exhaust first so we can tune it properly. The intake tubing was easy. The down pipe on the other hand won’t be. I’m using 2 1/2” schedule 10 304ss pipe.
Re: Andy's 91' 80q
Posted: Mon Jan 12, 2026 12:43 pm
by rennenmsports
- IMG_0093.jpeg (3.69 MiB) Viewed 4466 times
Re: Andy's 91' 80q
Posted: Mon Jan 26, 2026 6:15 pm
by rennenmsports
Re: Andy's 91' 80q
Posted: Tue Jan 27, 2026 9:27 am
by rennenmsports
It fits
