HT Motorsport
Post by HT Motorsport »
Plasma makes light work of this sort of fab eh Mark :)
Looks great!
I wil be at my shop tomorrow of you wanna swing by. I am leaving early afternoon though, back again Sunday mid day.....
Cannot wait to do some flowbench work ;)
( I have your video at the shop too)
timmmy wrote:Plasma makes light work of this sort of fab eh Mark :)
Looks great!
Thanks, the welds could be better but I was using 1/16 'gray' tungsten (zirconiated?) which is too thin for this sort of plate as it was all I had a halfway decent collet for. Those inverter tigs are looking better and better...
I'm going to try and swing by Rob's place to pic up a clutch fork but I will definitely be over at least one day this weekend.
I'll drop you a line when I get a time out of R&L that I can drop in, you're welcome to come play as well.
cool :)
HT Motorsport
Too late now but I have some heavier red electrodes if you have the collets to match.
BTW I have been using grade 12.9 instead of stainless for this sort of stuff recetly.
H
yeah, 12.9 is nice, overkill strength wise for this application although it never rusts anyway so its probably a good way to go.
HT Motorsport
The big problem I have been having with stainless beyond the fact that it is soft is that it dissimilar alloy corrodes next to mild steel making rust worse on the part next to it. plus it is soft, hence the 12.9.
interestingly grade 12.9 is a metric only thing and 8.8 is the same in SEA (very odd)
H
HT Motorsport
Hey Mark,
Time to change the title of your thread I think....
yodasfro
Post by yodasfro »
deleted
RS
Post by RS »
I second the bolt issue siding with Haydn. The stainless has a much lower strength which means you can't torque it as high as 8.8+ fasteners either. As loose bolts cause the most damage, I'd use non-stainless. With the rust issue, you know this thing is gonna eat clutches and tranny's so just replace all the bolts once a year when you pull the trans out. Adding the $5 for hardware shouldn't break the bank, but in the meantime use lots of anti-sieze to make sure they come out ok.
Metric "good" ratings are the 12.9 and 8.8. For all you non-metrics stick to grade 5 or grade 8 in standard sizes. To be honest I usually prefer grade 5 over 8 since they are more ductile. Strong impacts can sometimes snap grade 8's while grade 5's will bend and let you know there is a problem before the part falls off. Then again thats Jeep logic. Your coupe will probably see less rocks and trees.
a_CQ
Post by a_CQ »
Wow, good progress Marc.
I have a question for you. Do you think that 01E or just any B5 chassis shifter housing could be used with 01A on the Coupe, simply swapping over the linkage arm?
I hate B3 shifter housing design. It always feels sloppy, even with a short shifter. I believe B5 units are better.
As for Pro Con 10 - just remove it all.
Totally agree with Nate on the shifter, 01A is very straight forward and direct. I'd love to keep it but.. not gonna work on the 01E.
Brackets just came out of the oven :)
and in other news Mark Kramer's model plane got its first coat of paint. That things gonna be awesome:
Dye-Lohn NJ
Post by Dye-Lohn NJ »
bump for dupont(what i personally use) and a cool project :-D
o ya and page 52!!!!!
-Dylan
a_CQ
Post by a_CQ »
Replace the U-joint in the linkage, thats where your slop most likely is. The 01A's got the best linkage setup of all the quattro boxes.
Thanks. I'll look into that. Do you guys sell anything related?
3bAudios
Post by 3bAudios »
Today was my first time inside Mark's house to check out the planes...... they were awsome!!! your mounts came out really well, and i think im pretty sold now on trying to power coat everything on the underside of the 90 when i get there.....
scottmandu
Post by scottmandu »
The new 6 speeds have the 01A style shifter.
RSCoupe
Post by RSCoupe »
So Scott, will the stock 01A linkage in the CQ work, or are they just similar, and I'd still need the newer linkage?
scottmandu
RSCoupe wrote:So Scott, will the stock 01A linkage in the CQ work, or are they just similar, and I'd still need the newer linkage?
Not too sure yet, I haven't had a chance to compare these 6 speeds I got from Europe to an 01A, but they look very similar.
Stopped by Rob's shop yesterday and took an 01E clutch fork off his hands and wound up taking home some bonus carbon fiber brake ducts that wouldn't fit the bumper curve on his track car project as an added bonus ;)
Not sure if they'll fit the front end of the coupe either but worth a shot.
Anyway, here's a pic of the illusive clutch fork:
heading over to R&L engines in dover this afternoon to play with the flow bench and get some baseline numbers for the heads :woowoo:
Just got back from the machine shop, will need to work with Haydn this week to come up with some cad for some tooling that will be needed to get the heads bolted on to the flow bench.
the machine:
the plastic adapter that goes under the head to provide a sealing surface and a place for the head bolts to draw down on (this needs to be made):
sleeve that goes below the above plastic adapter. bore needs to be the same as the engine bore so this will need to be made as well. One option is to make a sleeve that will fit inside this piece, or it can be made one piece as well:
little adapter to push down on the valve assembly. Basically the stock valves need to be fitted to the head with the factory retaining hardware but very weak springs so they can be easily depressed with the tooling. This adapter provides a place for the dial indicator to press against to provide the correct amount of lift for the given test.
this is the adapter bar that the dial indicator mounts to. this pretty much bolts up to the head, although I will need to pull two of the valve cover studs and install some slightly longer pieces:
since it was warm today I decided to see if I could find where I left that tranny I pulled from the 5ktq when I did my first engine swap about 10 years ago into my 4000. I needed the drive flanges off the 016 to put on the 01E for my coupe. I did finally find it :-P
and these should be the flanges I need. yay!
yodasfro
Post by yodasfro »
I think you need 4kq flanges as they use smaller CV bolts like stock CQ axles do.
yodasfro wrote:I think you need 4kq flanges as they use smaller CV bolts like stock CQ axles do.
I suppose I should go check that....
fasterthenrs2
Post by fasterthenrs2 »
a4kquattro wrote:Just got back from the machine shop, will need to work with Haydn this week to come up with some cad for some tooling that will be needed to get the heads bolted on to the flow bench.
the machine:
Cool can not wait to see difference after porting
quattrofrog
Post by quattrofrog »
I see... so if I wrap my gearbox in a tarp and bury it in the snow..... then it will stay fresh forever! Good work Marc!
quattrofrog wrote:I see... so if I wrap my gearbox in a tarp and bury it in the snow..... then it will stay fresh forever! Good work Marc!
neighbors probably thought I was digging up a dead body :wtf:
s4 shifter box is in, fits *perfect*. I had to remove the studs since the CQ piece has nuts welded to the body on the inside. Still need to slide the tranny back in to see how much clearancing I will need to do for the rods to actuate smoothly tho. My adventures in digging up the 5ktq tranny didn't help though, yoda was correct, the flanges are too big, I need the 4kq variety :curses:
