Re: Jims 07K 84 Super HX40 4kq break in.
Sounds godly
audifreakjim wrote:Don't go E85, see how far you can push pump. I need to know :)
Me too! Stupid WA with the closest E85 1hr away
Sent from my XT1060 using Tapatalk
Post by glibobbo21 »
http://vimeo.com/96255519
Quick walk around my friend nick made.
PRY4SNO wrote:Sounds godly
:metoo:
This actually motivated me to go fix my headliner just so I could take it for a rip around the block :D
Those are from Nick's 200, and he is running basically the most aggressive hydro cam Cat sells. No dish on exhaust, and equal looking dish on the intakes. Do you have the spec sheet? we can compare with the JE's Nick has
Im not sure where the spec sheet is off the top of my head but i did send you a pic on fb messenger a couple months ago of it. Also, i have pics on fb of the physical pistons?
07k pistons 2.jpg (78.88 KiB) Viewed 28870 times
amd is the best
Post by amd is the best »
What CR Jim?
Nick
'00 A4 1.8t
'91 200 20v
'91 200 20v Avant
Zerb
Post by Zerb »
Wrist pin diameter?
posted from a computer in my pants
22mm tool steel. Yes 8.5:1
pete82
Post by pete82 »
out of interest how much did the rods/pistons set you back. I'm still very very interested in doing a 07k build just weighing up the costs first.
go On IE's site and fill your cart with everything the best except main bolts and there ya go.
everything is going well so far. crankcase ventilation needs some work but ive got a temp solution till i can spend a whole day remaking stuff. at least its not going all over the bay now. The car is ridiculous fast for this boost level and no VVT. very driveable off boost. cCouldnt be much happier right now with the car. Ive got probably 100ish miles on it now on the second oil change. one more 500 mile change after this 150-200, then synthetic. thinking Valvoline VR-1. open to debate...
Oh and go ahead and bitch about videos. Shawn has one and Ryan stopped after it stalled because my idle screw was adjusted too low...quitter
IM JUST THE DRIVER
There is some more launch control action of this car in here!
Curious why you're leaning toward Valvoline VR-1? Any articles, specs or hearsay you can offer?
I've long been partial to something along the line of a Total Energy9000 or Motul or RotellaT but am all ears for new info :)
Basically VR1 is the best bang for your buck as far as quality vs price. For an oil with a decent nickel content.
Forced Performance Recommendations for Motor Oil.pdf
(188.38 KiB) Downloaded 1240 times
Good info there - so what would a frequent change mean on these detergent free oils?
Good read, thanks.
WOMBAT wrote:Good info there - so what would a frequent change mean on these detergent free oils?
I'd say it's speculations without some kind of oil analysis, like what you get from Blackstone Labs.
Post by vt10vt »
This car is a good ass time
Sent from my SCH-I535 using Tapatalk
The car is still running well. I need street tuning since it wasnt reg'd at the time of dyno it was only tuned for a small amount of time idling and for power on pull on the dyno. Fouled one set of plugs after a "babying" ride on sunday not to mention reg and aggressive driving off an on. i keep being paranoid about clicky noises but its just the nature of the chains and nearly solid mounts everywhere and i less than "cushy" chassis. the lack of insulation in the older carpeting etc prob doesnt help either. Otherwise nothing exciting to report except injector cup adapters suck, I did pop an o ring out the other day with no fireworks caused by it. Pheww. Catchcan has been revised so it has screening to prevent so much oil slinging and drains back nicely. I may still need another vent or an actual suction line hooked up to the provent but at least 3-4 pulls doesnt throw a Quart of oil out now...
....after some street tuning it may be time to turn up the boost soon...
25 probably for now.
Don't you have an adjustable height fuel rail? If not, I can tell you who you need to talk to to get some top hats that are much better designed than the FIC ones. They're pretty cheap too.
How come you designed the fuel rail mounts with adapters?
Hank wrote:How come you designed the fuel rail mounts with adapters?
yup ha
